3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
50 Foot+ Rubber Band Rocket - New & Improved!
This rocket is based on a kid's toy I saw a couple of years ago that was pretty amazing for the materials involved. I decided to recreate it and see how well my version would work. It was a little heavier than the styrofoam toy that I had played with, but still seemed to work a lot better than you might expect. And, while you may have a rubber band big enough to reach low earth orbits, I haven't really done anything as far as heat shielding.  If you have kids that aren't quite old enough for model rockets, this is the perfect project for them.
I put the original version together in about a half an hour, and played with it for way too long to admit.  Eventually it got tore up, and now  I've decided to create a new and improved version.  This new version boasts some new features, almost all of which are designed to add distance.  Starting at the nose cone, it now allows for retractable rubber bands.  This will also allow multiple rubber bands to be used where it created too much instability in the original design.  The new body is a bit longer, and I figured out a way to help trim down it's circumference a bit and keep it rounder than before.  The tail fins are also much larger now to create more spin and ultimately more stability.  Finally, per a user comment I now also have a tool to launch the rocket with to avoid accidently thumping your finger on occasion.
Step 1Build the Nose Cone
Build the Nose Cone
The materials are very easy to find. You'll need (x2) 2-Liter soda bottles, a 20 oz. soda bottle, some paper clips and rubber bands. For tools I started with a hot glue gun and a pair of scissors. However, I also used needle nose pliers for bending the paper clip to nice angles and placing it in the body.  On the thicker neck of the bottle a saw will need to be used a few times.
To get started, we'll begin with the nose cone.  Cut off the neck of the bottle, leaving as much of the straight section in place as possible.  Next, unscrew the cap and drill a couple of small holes (the size of the paper clip) near the top on two sides.  I didn't have a drill handy, and used a small leather punch in place of the drill for now.  First, remove and save (without destroying) the sealing ring, then go ahead and put the paper clip in place and screw the lid down tightly.  Then you can mark the raised section of the neck for two more holes to keep the paper clip in place.  Unscrew the cap and make your holes.  Finally, make a hole large enough on top of the cap for at least a couple of rubber bands to fit through.
Now it's time to put it all together.  Take the paper clip out, and put the rubber band(s) on.  The strength, quality, and number of rubber bands you use will make quite a difference on how the rocket performs.  This design is a little heavier than the original, and needs a little bit more power to fly well.  The paper clip on the inside keeps them from falling down into the rocket later on, and you'll be able to dig them out with the launcher (built in the next step) if needed.  I placed a golf tee under them so they wouldn't fall back through.  I had to use a pair of needle-nose to get the paper clips forced through the holes further down the neck, but that will keep it from falling out.  If you need to replace the rubber bands later, it's probably just best to also replace that paper clip.
57 comments
1-40 of 57next »
Jan 12, 2011. 1:34 PMilpug says:
what did you do to your knuckle in step 5? nice instructable, by the way.
Jan 11, 2011. 6:47 PMThe Homemade Arsenal says:
This has me pretty intrigued... I'll have to make one for myself and mess around with it. I have a few extra airsoft springs floating around my workshop somewhere, kinda thinking that if the weight isn't too much i could potentially make a mechanism on the inside of the rocket that allows it to get power from the spring once the rubber bands are at the tension point and won't stretch anymore. I'll let you know how it goes :D
Also, Great 'Ible! its things like this that keep me addicted to this site =p
Nov 7, 2010. 11:27 AMdoomsdayltd says:
eh can't argue im in florida there is nothing to do here other than orlando
Nov 24, 2010. 6:49 AMBoppo3 says:
nah u cant argue with me... I'm from Singapore... there really isn't much things to do, since you get arrested for holding a weapon, or meeting with three or more people if u look suspicious. There really isn't as much freedom here than america, cos the freedom is sacrificed to make way for security... which is why there ain't much crime around here in Singapore
Dec 20, 2010. 11:36 AMdoomsdayltd says:
wow
Mar 24, 2009. 11:17 AMthen says:
best state ever:
Nov 24, 2010. 6:50 AMBoppo3 says:
pardon my ignorance but what does the bear on the flag signify??
Dec 18, 2010. 9:04 AMTurtledude_1 says:
the origin is accually a typo, it was suppose to be a "Pear", instead of a "Bear", but then what would the pear signify, i dont know....
Jan 29, 2010. 11:26 AMgHjM3W5T20YCS4e30 says:
jello biafra !
May 31, 2009. 7:30 PMbobby4505 says:
i now a kid in 8th now that got shot in cali in like 5th grade so it sucks too...
Oct 16, 2010. 2:43 AMpaul1999 says:
cool
Mar 19, 2009. 5:39 PMcorey_caffeine says:
excuse me but that isn't the louisiana flag...
May 31, 2009. 7:33 PMbobby4505 says:
no,loisiana is this, and it da best
Jun 1, 2009. 11:55 AMcorey_caffeine says:
i know i was pointing out that he should have louisiana up there
Jun 12, 2009. 10:42 PMbobby4505 says:
ooooooooooooooooooooooooooo lol i stupid
Mar 19, 2009. 3:19 PMBartboy says:
LoL. 50 ft? LOL
Mar 20, 2009. 10:20 AMBartboy says:
No, 50 ft is not that much. Plus, that does not look like it is 50 ft.
Apr 13, 2009. 7:07 AMbylerfamily says:
No,50 feet is not that much.In other words,you are saying that it is more than 50 feet.
Apr 13, 2009. 8:52 AMBartboy says:
No, I am saying something that only goes 50 ft doesn't go very far. And in the vide it doesn't look like it goes a full 50 ft.
May 31, 2009. 7:27 PMbobby4505 says:
its 1 rubberband.could u make a rubber band powered thingy go 50 ft using a 2 liter bottle(not using his design in any way) .
Apr 13, 2009. 9:59 AMbylerfamily says:
Well,build one and try it for yourself.I did and mine goes just as it should.
May 7, 2009. 4:27 PMbylerfamily says:
Congratulations on winning the contest.
Apr 17, 2009. 7:15 PMpineapplenewton says:
it needs to be heaver for more wind resistance
Apr 13, 2009. 7:33 AMbylerfamily says:
Wow!I love this thing.Made it myself and was amazed at how far it went.
Mar 21, 2009. 7:05 PMMadBricoleur says:
I think this one might have had a better chance of winning a contest if it was entered into the tap'dny contest :P just my 2 cents. Great idea!
Mar 28, 2009. 7:16 PMMadBricoleur says:
Actually, I think I'll have to really agree with you on those points. Good luck on winning the contest! haha :D
Mar 28, 2009. 5:56 AMbylerfamily says:
Yeah!Enter this in the epilog challenge and say its green because it reuses a plastic bottle.
Mar 28, 2009. 3:13 PMbylerfamily says:
My project I entered insn't epic either.
Mar 24, 2009. 2:30 PMclemsonguy1125 says:
i might just vote for this
Mar 26, 2009. 11:03 AMshrek150 says:
what state flag is that ????????????????????????????????????????????????????????????????????
Mar 26, 2009. 6:36 PMKryptonite says:
Seconded.
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:yokozuna
Whoever first said "sticks and stones can break my bones, but words can never hurt me" obviously never attended a ninja poetry slam.
