3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
50 Handy Tricks
Step 12Remove Bumperstickers and Pinstripes with Hot Air
A regular hairdryer works well for most bumperstickers.
For some pinstripes you need more heat, and a formal "hot air gun" is better.
If the bumpersticker isn't too old, the heat makes the glue soft and the decal flexible, so you can pull it off without ripping it. If your kungfu is good the glue will come off with it.
Otherwise you'll need to use laquer thinner or some other toxic laborsaving chemical to help remove it.
If the decal is very scratched or damaged by sunlight, you'll be scraping it off with a knife or razor like this gentleman at a boatyard in Richmond, California.
5 comments
Mar 31, 2012. 1:16 AMtechnogenuis says:
if you have acetone (in nail polish) that works well too since it eats plastic
Feb 10, 2008. 9:00 PMGrey_Wolfe says:
"Otherwise you'll need to use laquer thinner or some other toxic laborsaving chemical to help remove it." Actually, what works great for sticker (or tape) goo/glue, is hand sanitizer. Like Purell, anything alcohol based, that say it doesn't require water.
Apr 6, 2010. 12:33 PMdf00 says:
cost per ml hand sanitizer vs plain old methyl hydrate.
The trick with removing stuff is to match the solvent to the adhesive used.
Jan 15, 2010. 4:02 PMMT-LB says:
when i was little i helped my parents peel a ton of decals off our trailer. it was actually kind of fun!
Mar 24, 2008. 5:03 PMpechka says:
I've had good results spraying a bit of WD-40 on stickers, etc. Let it soak till it either comes off easily (or till you figure out that a given adhesive is insoluble in WD-40). Just found this site. Where've you been all of my life?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1249
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
