50v 5a Adjustable Power Supply
2,148
44
7
Published
Introduction: 50v 5a Adjustable Power Supply
Step 1:
make box
Step 2: Change Your 2power Supply Voltage
To change your 2power supply voltage you must change resister 10kohm to 12koh like in photo voltage will be 28.5v regulated
Step 3: Wires Connecting
Connect ac/in for 2 power supply and the output connect on series the voltage will be almost 55.8
that's will be input for DPS5005
Input voltage range: 6.00-55.00V
Output voltage range: 0V-50.00V
Output current: 0-5.000A
Output power range: 00.00-250.0W
Product Weight: about 113g
Product Dimension: 79*43*48(mm) (L*W*H) Open size: 71mm*39mm
Output voltage resolution: 0.01V
Output current resolution: 0.001A
Output Voltage accuracy: ± (0.5% + 1 digit)
Output Current accuracy: ± (0.5% + 2 digits)
Screen:color LCD
Charge the battery:Yes(but need a diode, it will be with module)
1. You must make sure that input voltage is 1.1 times higher than output voltage. 2. Under large curren circumstances, please pay attention to heat elimination. 3. When this product is used for charging a battery or connect a capacitive load, there must be a diode in series with the output-anode, otherwise the regulator will be damaged.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    7 Comments
    Hi. What about EMI? Do you need install any LC filters?
    Hello
    Emi filter founded in two power supply you don't need external emi
    This instructable shows a couple pix but says nothing at all... Why two power supplies??? I see a yellow wire but to somebody not an expert in electronics this instructsble tells me nothing... That's unless there is something hidden somewhere.... It does however tell me what I read on a web page making most of this copy and paste... Sorry...useless
    Look above you see that
