3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
55 Gallon Drum Vertical Axis Wind Turbine (VAWT)
Step 7Mount the Turbine
Mount the Turbine
Now, mount the turbine, attach the small gear to your generator, and mount the generator so that the gears fit together. If you don't have a deck like mine shown below, you can build a frame from 4x4s and 2x4s or adapt the design to mount on a pole (I am working on one of these adaptations now for a 6 barrel helical design)
Safety Considerations
1. Put a circular fence around the wind turbine using chicken wire or chain link to avoid personal injury (and personal injury lawyers). Even though my dog plays with my wind turbine, gears and other spinning objects can cause great harm, so be responsible
2. Don't hurt yourself building the turbine. If you can't handle power tools, use only hand tools (doable, but takes a little longer).
3. Don't place the turbine in front of your neighbor's picture window. He may come over with a shot gun :-)
The video below shows the hookup of the electrical generator. If you need gears you can get them here. Others have adapted chain and belt drives to make similar units.
Don't be afraid to alter the design to fit your skills or parts availability.
Here is a video made by dolnick. He took the basic design and adapted it with a belt drive instead of a gear drive. He also used a steel axle rather than a PVC axle and made his barrel mounts out of pipe mounts and 2x4 wood struts. He also used a salvaged motor instead of an automotive alternator. This was an excellent job and now succesfully powers a weekend vacation cabin running lights and notebook computer.
1 comment
Apr 22, 2010. 10:48 AMjgz says:
Did you build your own CNC Router to cut the gears?  If so, where can I get plans?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:embeddedprogrammer(Jeff's Blog)
Check out my blog for more information
