3310 5110 Lcd Screen Hesapal Up Resistor Color Code
1,621
Posted in TechnologyMicrocontrollers
Introduction: 3310 5110 Lcd Screen Hesapal Up Resistor Color Code
About: I'm from Turkey :)
Necessary documents hex code : 320volt.com/direnc-renk-kod-hesaplayici-devre-nokia-3310-lcd-pic16f88/
MOVİES: https://www.facebook.com/photo.php?v=1400128326931660
https://www.facebook.com/pages/Mekatronik-M%C3%BCh...
Hi.My name is mustafa.I from turkey.I was born in İzmir.Mechatronics engineering students. I have done you've shared circuit.hopefully benefit your business better days :)
#include < htc.h >
#include < stdio.h >
#define XTAL_FREQ 4MHZ
#include "delay.h"
#include "3310.h"
#include "resim.h"
__CONFIG(UNPROTECT & CCPRB0 & DEBUGDIS & UNPROTECT & UNPROTECT & LVPDIS & BORDIS & MCLREN & PWRTEN & WDTDIS & INTIO & FCMDIS & IESODIS);
unsigned char tus,tus_sayi=0; char direnc [4];//4 elemalık direnc renk kodu dizisi
//4x3 tuş takımı süren fonksiyon void tus_tara (void){ tus=0xFF; RB0=0;RB1=1;RB2=1; if (!RB3)tus=0; if (!RB4)tus=3; if (!RB5)tus=6; if (!RB6)tus=9; RB0=1;RB1=0; if (!RB3)tus=1; if (!RB4)tus=4; if (!RB5)tus=7; if (!RB6)tus=10; RB1=1;RB2=0; if (!RB3)tus=2; if (!RB4)tus=5; if (!RB5)tus=8; if (!RB6)tus=11; bekle_ms(400); } //Tuş numarasına uygun renk kodu ilgili satırda yazan fonksiyon void tablo (unsigned char deger){ switch (deger) { case 0: nokia_printchar ("Siyah ");break; case 1: nokia_printchar ("Kahve ");break; case 2: nokia_printchar ("Kirmizi");break; case 3: nokia_printchar ("Turuncu");break; case 4: nokia_printchar ("Sari ");break; case 5: nokia_printchar ("Yesil ");break; case 6: nokia_printchar ("Mavi ");break; case 7: nokia_printchar ("Mor ");break; case 8: nokia_printchar ("Gri ");break; case 9: nokia_printchar ("Beyaz ");break; case 10: nokia_printchar("Altin ");break; case 11: nokia_printchar("Gumus ");break;} }
// Bu fonksiyonda direnç değeri hesaplanır 3. renk koduna göre dierncin // ohm cinsinden değerini belirtir. 0,1 ohm ile 99 Giga ohm arasıdna direnç değerini hesaplar. void direnc_hesap (void){ char gosster[6]; nokia_gotoxy(1,0);nokia_printchar("Direnc=");
if (direnc[2]==0) {nokia_print(direnc[0]+0x30);nokia_print(direnc[1]+0x30);nokia_printchar("ohm");}
if (direnc[2]==1) {nokia_print(direnc[0]+0x30);nokia_print(direnc[1]+0x30);nokia_printchar("0ohm");}
if (direnc[2]==2) {nokia_print(direnc[0]+0x30);if (!direnc[1]==0){nokia_print(',');nokia_print(direnc[1]+0x30);}nokia_printchar("Kohm");}
if (direnc[2]==3) {nokia_print(direnc[0]+0x30);nokia_print(direnc[1]+0x30);nokia_printchar("Kohm");}
if (direnc[2]==4) {nokia_print(direnc[0]+0x30);nokia_print(direnc[1]+0x30);nokia_printchar("0Kohm");}
if (direnc[2]==5) {nokia_print(direnc[0]+0x30);if (!direnc[1]==0){nokia_print(',');nokia_print(direnc[1]+0x30);}nokia_printchar("Mohm");}
if (direnc[2]==6) {nokia_print(direnc[0]+0x30);nokia_print(direnc[1]+0x30);nokia_printchar("Mohm");}
if (direnc[2]==7) {nokia_print(direnc[0]+0x30);nokia_print(direnc[1]+0x30);nokia_printchar("0Mohm");}
if (direnc[2]==8) {nokia_print(direnc[0]+0x30);if (!direnc[1]==0){nokia_print(',');nokia_print(direnc[1]+0x30);}nokia_printchar("Gohm");}
if (direnc[2]==9) {nokia_print(direnc[0]+0x30);nokia_print(direnc[1]+0x30);nokia_printchar("Gohm");}
if (direnc[2]==10) {nokia_print(direnc[0]+0x30);if(!direnc[1]==0){nokia_print(',');nokia_print(direnc[1]+0x30);}nokia_printchar("ohm");}
if (direnc[2]==11) {nokia_printchar("0,");nokia_print(direnc[0]+0x30);if(!direnc[1]==0)nokia_print(direnc[1]+0x30);nokia_printchar("ohm");}
//son renk koduna bakılarak tölerans değeri hesaplanır. nokia_gotoxy(6,1);nokia_printchar("Tolerans=%"); if (direnc[3]==10)nokia_printchar("5 "); if (direnc[3]==11)nokia_printchar("10"); } //basılan tuşun değeri renk olarak diziye eklenir. void renk_ekle (void){ nokia_gotoxy(15,tus_sayi+2); tablo (direnc[tus_sayi]); tus_sayi++; tus=0; } //Ekran satırlarını siler ve satırlara 1,2,3,4 rakamlarını yazar. void ekran_temizle(void){ char i,j; for (j=0;j<2;j++){nokia_gotoxy(0,j);for(i=0;i<14;i++)nokia_print(' ');} for (i=1;i<5;i++) {nokia_gotoxy(3,i+1); nokia_print(i+0x30); nokia_print('-'); for(j=0;j<9;j++)nokia_print(' ');}}
void main(void) { int i; OSCCON=0x6C; TRISB = 0xF8; TRISA = 0X00; PORTB = 0XFF; PORTA = 0x00; CMCON = 0x07; ANSEL = 0x00; RBPU = 0; nokia_init(); nokia_gotoxy(0,0); for(i=0;i<504;i++) nokia_write_data(resim[i]); bekle_ms(500);bekle_ms(500); bekle_ms(500);bekle_ms(500); nokia_clean_ddram(); ekran_temizle(); nokia_gotoxy(18,0); nokia_printchar("Renkleri"); nokia_gotoxy(18,1); nokia_printchar("Tuslayin");
while(1){ tus_tara(); if(tus!=0xFF){ switch (tus_sayi){ //1. renk olarak siyah ,altın ,gümüş girilmesini önleyen kod case 0: if ((!tus==0) && tus!=10 && tus!=11){ekran_temizle();;direnc[0]=tus;renk_ekle();}break; //2. renk olarak altın ve gümüş girilmesini engelleyen kod case 1: if(tus!=10 && tus!=11){direnc[1]=tus;renk_ekle();}break; //3. renk olarak bütün renkler girilebilir. case 2: direnc[2]=tus;renk_ekle(); break; //4. renk olarak altın ve gümüş harici renk girilmesini önleyen kod case 3: if(tus==10 || tus==11){direnc[3]=tus;renk_ekle();direnc_hesap();tus_sayi=0;}break;}} } }
Step 1:
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    2 Comments
    Danger is my middle name : Which place did not understand?
    Can you explain the second step a little more? You have a lot of pictures but it's hard to tell what everything is.
