Introduction: 555 Astable Keyboard
Picture of 555 Astable Keyboard
The 555 timer is a powerful chip for a low cost oscilation system. By adjusting the components that you attach to it, you can make it oscillate faster or slower. Hook that to a speaker and you get a nice 555 Keyboard.
Step 1: Parts List
Picture of Parts List
Here is the list of parts you will need. You can get them at any local electronics shop, or you can order them online.
1 protoboard
1 1k resistor
3 10k resistor (4 shown, found out you didn't need it when wiring up the circuit)
1 220 ohm resistor (not shown)
13 Tactile buttons
13 trimmer pots
1 8 pin dip ic socket
1 555 timer
1 .01 uf capacitor
1 .22 uf capacitor
1 9v battery clip
1 9v battery
1 8 ohm speaker
Tools needed:
Solding iron
Hot Glue
Wire cutters and strippers (not shown)
Step 2: Adding Buttons and Trimmers
Picture of Adding Buttons and Trimmers
To start, orient your protoboard such that all the keyboard buttons fit onto the board with enough room for your fingers to play them. I put a single hole gap between each of mine, but depending how you want to lay out your board, you can make them closer or farther appart. I added 8 buttons to the bottom row, and 5 offset above. If you want it to look like a piano this layout makes sence.
When you finish adding all the buttons, repeat this pattern about 3/4 to an inch away from you buttons. Following the same pattern will help make it easier to tune later on. For the first 3 buttons, the 10k trimmer is not big enough of a value for the 555 circuit, so add a 10k resistor. I originally had 4, and there are 4 pictured, you you only need three. Do not add the one farthest to the right.
Solder these onto their pads to keep them in place.
Then solder a long jumper wire to every other terminal on the buttons, meaning solder the wire to the right or left side of each button. but not the other side of each button. Try to keep this consistant. it will help you latter.
Do this again with the potentiometers. This time solder all the pin 2 connections together on the bottom side of you board.
Step 3: The 555 Circuit
Picture of The 555 Circuit
To begin your 555 circuit, i recommend that you breadboard it first. Test everything out and make sure that you're circuit is going to work before you start soldering. You will see the 555 circuit move at this point for me because i messed up. Lesons learned.
1. Solder a jumper wire from pin 4 to pin 8. The piins go ccw arounf the chip, with the little notch indicating the pin 1 location.
2. Add a jumper from pin 7 to the wire connecting all your buttons together on the bottom of your board. Add the 1k ressitor from pin 4 to pin 7. I just had it jump to the button leads because it was easier.
3. Add the .22 uf capacitor such that it is between pins 2 and 1. If you are using a polarized capacitor, have the negative side connecting to pin 1.
4. Add the .01 uf capacitor, connecting from pin 5 to pin 1.
5. Add the 9v battery clip by soldeing the positive lead to pin 8 and the negative lead to pin 1.
6. (had to meove the circuit at this point) Solder in the 220 ohm resistor. Connect one side to pin 3, and the other side move into an open area.
7. Solder 2 long leads to the speaker. Solder the negative lead to pin 1 and the positive lead to the end of the 220 ohm resistor not connected to pin 3.
Step 4: Finishing Up: Jumpers and Tuning
Picture of Finishing Up: Jumpers and Tuning
For the last little bit of soldering, add a jumper from the buttons to the potentiometers. If the button is paired to a 10k resistor, jump to that first, then to the potentiometer.
When adding the jumper, solder to the opposite corner from which you soldered the jumper wire to. If you added the jumper to the left side of each button, connect the jumper to the right side of each button. Connect each button to it's respective potentiometer's pin 1.
To tune your piano, you can do it by ear. Using a small tone generator app on my phone, I adjusted each potentiometer to match it's respective piano tone.
Now all that's left is to hot glue the speaker into place on an open section of your board, plug in your 9v battery and...
Step 5: Done!
Picture of Done!
The piano is done! You should be able to hear your speaker oscilating and ouputing the different notes when you hold down the button for each key!
PrashantK23 (author)2016-07-30
Please please please provide the circuit diagram.
atanvir1 (author)2016-07-01
Well, The circuit seems kind of mmm... messy. It would be so kind of you if you give the schematic.
rah187 (author)2016-05-26
Great build! I am planning a huge audio/electronics project which involves extensive use of oscillators and synthesizer. This falls under the catagory of square wave oscillators, which is exactly what I need. I am about to order parts for this project, and there is just a little confusion as to where to place the parts in the circuit, but I am sure I can easily resolve this problem.
thewestafrican (author)2014-03-27
what is the range of the potentiameters you are using
ElectronicsGeek (author)2013-08-14
Very nice build, tycoonist. Might I ask what the octave range is. For example does it start at middle C? (C⁴)
loptica62 (author)2013-06-16
Wish I could have a look at the bottom side of the PCB.... Or a schematic drawing would be nice too....
cbm7b5 (author)2013-04-22
Awesome! I'm going to build this into an SNES controller, as it has 12 buttons for a chromatic octave. Thanks for sharing!
amandaghassaei (author)2012-10-01
AH this is sooo cool! Seems like you've got it tuned pretty well too. can you post a schematic?
tycoonist (author)amandaghassaei2012-10-01
I would post a schematic, but it's just the 555 astable circuit. I used the one found here.
http://www.ohmslawcalculator.com/555_astable.php
This is the same program I used to calculate the R values for the potentiometers. Basically, I just pulled R2 into 13 different parallel paths with a button on them. Press the button, close the circuit, and make the pretty noise. :D
quatch (author)tycoonist2012-10-03
not quite sure I follow the way the buttons are chained.
amandaghassaei (author)tycoonist2012-10-01
it would be cool to see how you set up your resistors.
Kiteman (author)2012-09-30
What kind of protoboard did you use? Are there individual copper pads underneath, or strips? If strips, which way are they oriented?
tycoonist (author)Kiteman2012-10-01
The perfboard is a simple pph (pad per hole) board. When it came to connecting to the pins, i would bend the wire over and solder it to the next wire and solder it to it's own pad.
About This Instructable
16,730views
98favorites
License:
Bio: EET student at Broome Community College. Amateur Radio Operator. Model Railroader.
More by tycoonist:555 Astable KeyboardMake a Diorama Using Foam
Add instructable to:
