555 Timer
12,613
47
Posted in TechnologyElectronics
Introduction: 555 Timer
In this instructable i will teach you every thing you would ever need to know about the 555 timer IC. If you already know about the chip you could check out my slide show titled "47 projects to do with a 555" it will teach you every basic project to use a 555 with, its great for beginners!
I do not take 100% credit for this. source link on each step.
Bistable mode or Schmitt trigger: the 555 can operate as a flip-flop, if the DIS pin is not connected and no capacitor is used. Uses include bouncefree latched switches, etc.
Step 1: 555 Timer Pin Diagram
The 555 Integrated Circuit (IC) is an easy to use timer that has many applications. It is widely used in electronic circuits and this popularity means it is also very cheap to purchase, typically costing around 30p. A 'dual' version called the 556 is also available which includes two independent 555 ICs in one package.
For the 555 to function it relies on both analogue and digital electronic techniques, but if we consider its output only, it can be thought of as a digital device. The output can be in one of two states at any time, the first state is the 'low' state, which is 0v. The second state is the 'high' state, which is the voltage Vs (The voltage of your power supply which can be anything from 4.5 to 15v. 18v absolute maximum). The most common types of outputs can be categorized by the following (their names give you a clue as to their functions):
Monostable mode: in this mode, the 555 functions as a "one-shot". Applications include timers, missing pulse detection, bouncefree switches, touch switches, frequency divider, capacitance measurement, pulse-width modulation (PWM) etc
Astable - free running mode: the 555 can operate as an oscillator. Uses include LED and lamp flashers, pulse generation, logic clocks, tone generation, security alarms, pulse position modulation, etc.
Step 2: Shematics for 555 Timer
R1= 33KOHM
R2=33kohm
R3=1kohm
C= 10uF 50v
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Pocket-Sized Contest
    3 Comments
    Using a 100k Ohm as R2 will make the led light 1 second. FYI
    i an new with 555 timer ,but this article helps me to get little more understadninf about ICs thanks i also made some basic circuit at my blog techmess.page.tl
    hope you guys help me to become a nerd
