3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
555 Timer LED Flasher
The first project I ever built was a light that blinked on and off. It took nine parts and a couple of wires. Nice and easy.
Using some resistors and capacitors, I basically configured a 555 timer chip to act as an oscillator (fancy term for something that generates electrical pulses at regular intervals). I used the pulses to drive an LED, which turned on whenever there was a pulse and turned off whenever there wasn't a pulse (thus the blinking action). In technical terms, this circuit is called an "astable multivibrator."
This is a great project to start off with if you're thinking about doing electronics. Here's what you'll need:
-U1: 555 Timer IC
-R1: 1 megohm potentiometer
-R2: 47 kilohm resistor
-R3: 330 ohm resistor
-C1: 1 µF electrolytic capacitor
-C2: 0.1 µF (100nF) disc capacitor
-LED: 5mm red LED
-9V battery
-Solderless breadboard
Just assemble the circuit according to the attached schematic diagram (555 LED flasher.pdf), and you're set. For a nice explanation of how this actually works, visit the Electronics Club's 555 Timer page here.
Note: A month ago, I made an improvement to my original design that allows me to drive two LEDs instead of just one. Basically, the LEDs are connected so that whenever there is a pulse from the 555 timer, the red LED turns on and the green LED turns off, and whenever there isn't a pulse, the green LED turns on and the red LED turns off. I have included the corresponding circuit diagram (LED Flasher 2) with this Instructable.
3 comments
Feb 17, 2012. 7:53 AM12amedle says:
now i assume they flash but do they have a strobe effect? and how would i turn this into a 12v system? thanks
Dec 29, 2011. 12:03 PMBassem Adel says:
My firist project was a flasher but not like this i used 2 transistors pnp
4 resistors 2 capacitors 2 leds
in your circuit the 2 leds lighting and close in the same time ??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ThatCaliforniaGuy
Hi! I'm Dave, and I've lived in China for about three years now. As my username suggests, I'm from California, so naturally, I miss the sunshine, the beaches, and the crisp evening air. In my spare ...
more »
