3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
555 timer radio
555 timer radio
  • Changes have been made to this instructable, these changes are denoted by asterisks ( * )
A single station 555 timer radio from a few simple and common parts. Switches between an oscillator and AM radio receiver. A few things I should warn you about before you get too excited...
1. This is a simple circuit I built by accident, it does not mean it is the best way to build it.
2. I'm still new to circuit mathematics so it have a few problems or calculations that could help find a better solution for this circuit.
3. It's currently a single station radio (I don't actually know the range because I think I live within a 1/4 mile of the station I'm receiving from)
4. It's really static-y and voices are a bit garbled (the first time it worked i thought it was just the capacitors discharging and having the trimmer resistor in between resistance values), I believe you can get it in a better quality with a few more electronics but i haven't tested that theory out.
If you can help me in any way, leave a comment and don't leave comments that don't actually help any other readers reading this instructable.
Also note: I do in fact know the pics are pretty low quality, I'm still getting used to my new camera.
Step 1The parts you'll need
The parts you\
*3 resistors - *220 ohm, *100 ohm, *1 Megohm
*3 capacitors- 2 x .01 microFarad, *10pF ( .00001 microFarads = 10 picoFarads) You can use a 10 microFarad capacitor if you do not have a 10 picoFarad capacitor (you can get them in a value packs at Radio Shack)
  • approx. 6 or more inches of single solid-strand wire (or an antenna)
1 LED (optional)
1 555 timer IC chip
*2 trimmer resistors or potentiometers- (It's ok if this isn't exact) 83 kilohm
*1 8 ohm speaker (not a 'beeper', a piezospeaker will work but it's not really worth it because it's very quiet)
1 9v battery and 9v battery connector (note: What I'm using is a 5v (wall) power supply from a different breadboard but a 9v will do just fine)
14 comments
Jun 10, 2011. 3:25 PMapaterson1 says:
hi for your receiving capacitor you should use a variable on that should change stations
Dec 8, 2010. 9:14 AMnaveen.sai451 says:
great work
Aug 25, 2010. 6:29 AMASCAS says:
In a NE555 chip i think you just need to change the capacitor to change the frequency. try adding a trimer cap. =)
Jul 5, 2010. 3:42 AMlxkarthi says:
what is exact frequency of this radio? can u provide me a simple circuit for transmission also?
Jun 25, 2010. 10:29 PMfd18 says:
The LED across the speaker contacts could cause "turbulence", in terms of resistance...maybe. Just assuming
Mar 26, 2010. 10:10 PMsur says:
it would be better if u please tell us something about the working of the circuit.. like how the circuit works with signals n how triggering and threshold takes place?
Jan 2, 2010. 11:52 PMaliyevzaur1989 says:
How can i work?!
It doesen`t even have a coil?!  O_o
Oct 8, 2009. 2:02 PMmattccc says:
is it am or fm
Nov 15, 2009. 11:12 AMshawntherobot says:
it says on step 3 it AM but very crackly and 1 station
Jul 30, 2009. 7:05 PMqwertyboy says:
this is pretty cool. hint: try using the macro setting on your camera (normally denounced by the flower setting) and make sure you have good light.
Jul 25, 2009. 10:26 AM8bitprodigy says:
as far as changing stations, try swapping out one or more of the resistors with a potentiomenter (variable resistor) until you find which one controls it. have fun.
Jul 24, 2009. 11:31 AMbrunoip says:
good work !
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:MacDynamo
