5V Ac to DC regulated powersupply
 by mysterion
So I've been searching for ways to make my own power supply so i can stop using so many wall warts.  I use alot of DC, i'm tired of 5v 350ma small fries.
I'm working on an ATX power supply but it lacks the compact portability I need in a simple power supply.
This cost about $5.50 with the step down transformer being the most expensive part.
Supplies:
Old power chord (free)
Step down transformer ($3.00)
Full Wave Bridge rectifier (50V 4A) ($1.50)
Glue
5V regulator (I used an L7805CV 1.5A max) ($1.00/3)
smoothing capacitor (I used 100 uF 35V (free))
wire (free)
And the essentials: soldering iron flux solder, electrical tape, heatshrink tube, pliers, lighter, ect.
JJBuck10 says: Feb 16, 2013. 8:31 PM
Where did you find the transformer? I can only find them for $15+
mysterion (author) in reply to JJBuck10Feb 17, 2013. 6:41 AM
eBay, the stuff from china I searched ac transformer 110 to 12
MaheshPrazad says: Oct 3, 2012. 1:03 AM
i have a transformer of 14V secondary with 500mA current.Can i make the current 250mA somehow.The question is not exactly related to this but i wondered if could get some answer.
Thanks.
mysterion (author) in reply to MaheshPrazadOct 3, 2012. 5:26 PM
From what I know of AC the current rated on your transformer should be the max it can supply. All the transformers I've used have just a wattage rating.
It will probably have to be in your circuit that limits the current.
Just a shot from everything I know of AC currents.
MaheshPrazad says: Oct 1, 2012. 12:40 PM
some use decoupling capacitors as well in the circuit.What is the purpose of that/?
mysterion (author) in reply to MaheshPrazadOct 3, 2012. 5:16 PM
That is used to filter out noise caused by other parts of the circuit.
When your load increased suddenly you will increase a draw on the current from the supply, that causes the voltage to change too. The capacitor just acts as a little storage so the voltage doesn't drop during increased loads.
MaheshPrazad says: Aug 19, 2012. 7:35 AM
what if i want to make a 9 volt DCsupply
mysterion (author) in reply to MaheshPrazadAug 28, 2012. 10:28 AM
Sorry for the long reply i've been moving,
Just replace L7805CV
with a LM7809CT, a 9V regulator
MaheshPrazad in reply to mysterionOct 1, 2012. 12:42 PM
thanks a lot.
rimar2000 says: Apr 16, 2012. 6:52 PM
Thanks for sharing, this is very useful.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
