3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
5V stabilised supply for USB hub
This is a stabilised supply intended to be used with a bus powered USB hub in order to deliver a stabilised + 5 volt supply to the devices connected to it.
Due to the resistance of the connecting cable, and the resistances introduced for current sensing for overcurrent protection, the voltage at the hub can be anywhere between +4.5 V(loaded) and +5.5 V. This circuit will deliver a stabilized +5 V in both the cases, ie, it is a buck/boost design, using the TPS63000 switch mode regulator chip manufactured by Texas Instruments.
It can deliver +5 V at 500 mA from input voltages as low as 2 Volts so a rechargeable battery and its (USB powered) charger can be added to make this into a USB UPS for the USB hub.
Step 1Preparing the circuit board
I decided to do a ground plane based layout. The chip has ten solder pads and a thermal pad to be soldered, and this was a different method to try with these types of leadless packages.
A scrap of single sided paper phenolic copper clad was cut to size and the outline of the chip drawn on its unclad side.
Then with a small screwdriver sharpened into a chisel, material was removed, making a niche for the chip to sit in.
16 comments
Sep 9, 2010. 2:45 PMGENERALCHAOS says:
i have a 7 port chip gate from Ti would it work for all 7 port or 4 only ?
May 7, 2009. 7:48 AMp3ngwin says:
i just got one of these chip samples from TI, and after i buggered one of the pins i was looking for other people that may have used the chip. and, lo, i found this page. i need a buck/boost like this for a small solar bike lights project and a solar USB power supply. anyone know where i can get an assembled board like this or any other circuit that will do the job?
Oct 21, 2008. 3:15 AMEsmagamus says:
I liked the design of the circuit, but the final result... You should try ExpressPCB. It's really easy to use and you can design every circuit you want easily and make pro-looking boards with the toner method. Keep up the effort.
Feb 22, 2008. 7:39 PMraykholo says:
um, what does this do? it does look cool and high tech though but i dont get any of it
May 6, 2008. 8:19 PMraykholo says:
much better thanks
Mar 13, 2008. 9:03 AMXellers says:
Although this project is great, I must admit that the pictures arn't great and it looks as if you did a somewhat messy job with the wiring.
Mar 14, 2008. 12:39 PMXellers says:
I understand...
Jun 26, 2007. 6:06 PMIan01 says:
Two questions: 1. What is the red wire for around the inductor? 2. Why did you unwind and rewind the inductor?
Feb 15, 2007. 9:53 PMdwarven says:
the schematic diagram was preety ..the part component was complex
Nov 30, 2006. 2:43 PMLasVegas says:
stabilize |ÈstbYÌl+z| verb make or become stable : [ intrans. ] his condition appears to have stabilized | [ trans. ] an emergency program designed to stabilize the economy. • [ trans. ] cause (an object or structure) to be unlikely to overturn : the craft was stabilized by throwing out the remaining ballast. DERIVATIVES stabilization |ÌstbYliÈz sh Yn| noun :)
Nov 30, 2006. 3:44 PMBruceR says:
Britain and America, two nations separated by a common language.
Nov 30, 2006. 10:50 AMrotor says:
I am 200% in love with these destroyed-looking devices. Please do an instructable on the saltwater etching process you used in your other usb hub.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:neelandan
Employed as an Engineer in Electronics. Interested in building small circuits around tiny chips (the electronic kind).
