loading
Step 6: Arrow Variations
Variations:
-If you have a longer skewer with which to make a bow, keep the shorter skewers full-length to make arrows
-You needn't needle-point the arrows, but you will want extra weight at the point-end, so come up with some other weighting method
-You can try splitting the arrow skewers into thirds and fletch them with the triple fletching real arrows usually have
<p>Could you use Bamboo chopsticks instead of skewers? or are they too ridged? </p>
None of the bamboo chopsticks I've ever seen could be flexed more than a few millimeters, so no, you couldn't use chopsticks without modification. You may be able to split a chopstick down into slimmer sections that could flex enough for this project, but I haven't tried it. I wouldn't try it with the non-disposable type, though: they're probably too solid/rigid/sturdy.
Isn't the skewer already pointy? But the nail is cool
This is a good instructable
might make it into a crossbow.. now that would be cool!!
thanks.this is just what i needed.since i've been umemployed,i needed a simple project to keep my brain occupied.
I am soaking the bow shaft in water for it to be flexible. Is that OK? I think i need to make a nock for the arrow to sit on the string, but the skewer is too small for me to cut it with a knife, any way to do it?
Soaking the material is usually done when you want it to hold a shape on its own. If you're having issues bending the bow piece into a sufficient curve, then soaking it will help. (Be careful, though, since it will reduce the power of the bow.) As for the nock, here's a few suggestions: -Wrap fine sandpaper around something like a credit card and file the nock -Wood burner/heat a narrow piece of metal and use it to char a notch out (but make sure you don't mind ruining the temper on the metal) -Triangular or square files (hobby-sized) -Jeweler's saw *Though if you've already split the rear of the shaft to allow for the fletching, then you can just carefully sand down each side of the split to create a notch when the sides are stuck back together.
&nbsp;the bow kinda looks like a pencil, but cool anyway
&nbsp;wow. you're pretty smart for a 7 yr old.
5 starz
i used to shoot people with my mini crossbow when iwas young .Good times
my only problem was i shot it and it recoshaded of the wall into by leg. it whent in 2 inches. But on the bright side now i dont have to get my yearly shot!
You filled your darts with medicine? I hope I never meet you.
HE'S JOKING (i hope)
Check these out...
:D Post that as an Instructable!
thats pretty cool
dis is kool i want 2 make 1 i jus need wood
use wooden chopsticks and glue them into a long line by using 2 but make sure u put the thin ends opposite to each other send me pictures when your finished
woooow dude i posted that comment like a year ago.where were you haha
this is my account and actually a year ago i didnt even know of this site so haha to u
what?
combine your arrows to this bow:http://www.instructables.com/id/bamboo_skewer_bow_1/?ALLSTEPS<br/>
too big to make though ive made on ove these before sp please but pics on plz
I was shot with one of these that my friend made, it went really far in and now 1 year later I still have a scar. It really hurt
this is awsome, but i ignored the "at your own stupidity" and fired it up in the air and missed myself by..... not much
LOL
kool, i'm so trying it
sick, thats awsome, i'm surly going to try it
Beautifull
nice arrows i had like them but build from straws and glue gun and toothpick there easier to mmake and not that dangerous
wow, I didn't know I already posted here, heh.
Awesome, I used to make these too, but didn't add the fins to the end. Try steaming the bow wood overnight so it won't splinter when you use it the next day. Afterwards, keep the wood oiled.
i just made one. it is good.
hey check out the bow ive designed made from skewers 2!! <a rel="nofollow" href="http://www.instructables.com/id/EASY-skewer-bow-and-arrow/">click me</a><br/> <br/>
hhhmmmm. im not sure if this will work. but go to michaels and get a pack of dowels. then do what redrogue said and soak it in hot water overnight and use that as the bow. imma go try that.
you should put it on a cross bow (be stronger) :p
paper clip bows work better. they dont crack. this looks nicer though
i used a pencil for the arrow i split it in half the long way then super glued a needl in it and hot glued it together then put hot glue in it to help hold the needle in
soaking the bow in hot water overnight makes the bow much more springy and durable
I used to do this, sold them 1$ each, but didn't add the needles and feathers
dang. nice. i just made it and im bout to go and test it. even if mine doesnt go far, it still looks awesome.
i once made a bow from plastic spoon handles, i might post an instructable later lol
I am now blind in one eye due to a similar device we built back when I was in school. Ours was made using Q-tips and needles and it was all fun and games until I got an eye put out. Just be carefull if you build one of these.
i tryed to make a bow with wood ones but they always broked in half
ah so i'm not the only one crazy enough to think of this lol. i made a few of these a couple years back. i didn't put the needles in my arrows, just sharpened them (tho i did use some in some blow darts i made about the same time). even made a mini cross bow by taping some skewers tightly together at intervals to make a wider/stronger bow and mounting it in a grooved scrap of plywood. it had a detachable handle for storage and a "trigger" that for the sake of simplicity pulled down rather than back. used real feathers (local seagulls were moulting all over the place) for the flights and did 3 with a slight spiral rather than 2 straight ones.. hmm i wonder where i put that thing.
im working on a crossbow, check it out when im done. it will be called "scale wooden "crossbow. I is 1m byt 1m and has kick to it! nice simple construction though
damn that's a good idea i wanna make a crossbow when i get home
About This Instructable
31,463views
55favorites
License:
More by ryzellon:Repairing a Nintendo DS Lite Make a sling (weapon) out of a grocery bag! (Plus two bonuses! "How not to use scissors" & "Replace bandaids with sports tape") Chainmail(le) Primer: Making Jewelry-Size Rings for Weaving Chainmail
Add instructable to:
