iImage Information
I just came back from the Christchurch SuperShed (our city council recycling centre) where I bought a discarded slide projector for $6. In less than an hour, I turned the projector lens into a tilt macro lens for my dSLR. I know there have been lots of these sorts of projects but I tried to do this one without hot glue or gaffer tape so hopefully my process will help you to turn your odd lenses into useable ones.
Step 1Finding the right lens
iImage Information
Any lens can be adapted as long as the distance from the back of the lens to the focal point (slide, film, or whatever it is projecting from or to...) is more than the distance from the flange (where the lens attaches) to the sensor. Don't stick a ruler into your camera, just look it up. For my camera (Olympus 4/3rds), the flange distance is 38.67mm (Wikipedia - Lens Mount) and the back of the slide projector lens to where the slide would be is around 45mm.
This lens has a focal length of 85mm, and compared with some of the other lenses I saw, I guess it is about f2.8. I should point out that most projection lenses do not have variable apertures so you have to shoot with them wide open (shallow depth of field). This one has a spiral groove which makes it easier when enabling twist focus.
i am currently experimenting with the shift and tilt thing,hav orderd enlarger lens off ebay,also disasembled a ded sony handy cam,when iv got several slide/stuper8 projectors sitting in the attic.
looking forward to reading the rest of your adheisve free approach to assembely
With this in mind, I could distill this instructable into a few phrases:
1) Its fun to see what types of lenses can be turned into usable ones for photography, and how you could do it.
2) You don't have to spend hundreds of dollars on lenses to get reasonable photographic results.
3) Don't throw anything away until you make sure you can't upcycle it.
jk lol
Lookin for an old projector lens now.
Maybe you could combine it with this other 'able
http://www.instructables.com/id/iSteadii-20-Image-Stabilizing-Unit/
