Requirements for the rack would have to be: holds as much gear as possible, hold the gear neatly and safely, break down for travel into as small a size as possible, easy to put back together and be light for travel purposes. Each rack is designed to fit on 1/2 of a 6 foot table so we can put 12 guns and masks per table. We currently have four of these racks for all the players on the team to use.
This version of the rack we will be building was built and designed by Chuck "Chucky Cheese" Canesi. I just reverse engineered it and posted it here.
You can find out more about the paintball team Pub Crawling at www.PubCrawling.Org.
Remove these ads by
Signing UpStep 1Material List
32 1/2 inches Tall
16 3/4 inches deep
36 inches wide
Material List
3/4 inch schedule 40 pvc pipe Approximately 24 feet
(8) T connectors
(6) 90 degree elbows
(3) Crosses
(6) pipe Caps
(6) 9/16 nuts
(6) Barrel Holders
(6) Tank holders
(12) 3/4 inch screws
60 inches of weather stripping
(1) 5/8 inch dowel rod 30 inches long
The few notes I'd make on the process:
I used two 10' PVC tubes. The vertical bars were only 29 inches, and the mask holders were slighly shorter (maybe by an inch or so) but in the end I had literally a one-inch piece of tubing left over. Not sure where you'd use the extra 4' of PVC tubing your instructions called for, but happy I decided to chance it and only get 20 feet.
For tank holders, I got two 4" PVC coupling sections, and cut them down the middle horizontall and vertically, giving me 8 possible tank holders. I drilled out three holes like you did to attach them to the PVC/dowel combo (nice trick with the dowel btw, very clever!), and after leaving just the two outer screws in (not the third), the 4" diameter spread out slightly wider, since 68ci/4000psi compressed air tanks are 4.3" in diameter.
I picked up some pipe clamps which came in 4 pieces (two sets, top/bottom), and folded the 'flaps' over. I used a steel drill bit to drill out a single hole, put a nut/bolt combination on them, and fastened everything tightly. I bought a bottle of "liquid electrical tape" but decided against it and just covered them with the same 3/4" weather stripping I used on the tank holders. I had seen some plastic-coated tool clips for about $2 each for hanging tools on a wall, but decided they were too expensive.
The weather stripping is nice and padded, though the 4" PVC was slightly wider (almost 2" wide) than two strips of the 3/4" stripping I bought (should have bought 1" stripping).
The only addition I'm going to make is to pick up something to cap the ends of the mask bars. Either 6 more caps, or 30-degree elbows for a 'hook' so masks don't slide off since the bars are slightly shorter than the instructions called for.
Can't wait to try it out this weekend.
Full-size image
In general, Home Depot staff were insanely helpful to find parts once I described what it was I was trying to build. A few of the older guys looked at me funny about how to find something to hold the tanks. They sell strips of sheet metal which you could bend, but that would require (a) bending the steel, (b) not slicing your fingers in the process, and (c) maintaining the shape.
I also recommend picking up the 20' of PVC tubing LAST so you have have to wheel that stuff all over the store.
