loading
Step 6: Two Uprights for the Mask Holder
(2) 29 1/2 inch pieces of PVC pipe.
(2) 90 degree elbows
Put one of the elbows onto a pvc pipe and the other end onto the T connector on the base.
Repeat for other side.
<p>What are the tank holders actually? I'm having difficulty finding whatever they are, it's the remaining piece I need.</p><p> If possible can you post a link to Lowes or Home Depot?</p><p>Appreciate any help!</p>
The Tank holder piece started as a flat bar of metal and was bent to be round for a tank. I think when I took a quick look at the home depot site it was something like this. http://www.homedepot.com/p/Crown-Bolt-1-1-2-in-x-96-in-Aluminum-Flat-Bar-with-1-8-in-Thick-56900/100338251. OR http://www.homedepot.com/p/Everbilt-1-in-x-48-in-Aluminum-Flat-Bar-with-1-8-in-Thick-801927/204274000 Or Similar. (sorry don't have in front of me to look at) You would cut them to length, Drill your holes and counter sink them. Then bend them over something roundish. https://www.instructables.com/file/FP6Y3E6GM9QKW8W/ <br>
How much did you pay for all the parts?
Tough to say since I usually have lots of PVC pipe pieces laying around from other projects like water rocket launchers and stuff. Ian below said his was about $26 bucks. I would say that is probably a good estimate.
Thanks for the great, detailed plans. With some slight modifications, I made one for about $26 in parts from Home Depot and several hours of labor (most of it measuring/cutting the PVC tubing).<br> <br> The few notes I'd make on the process:<br> <br> I used two 10' PVC tubes. The vertical bars were only 29 inches, and the mask holders were slighly shorter (maybe by an inch or so) but in the end I had literally a one-inch piece of tubing left over. Not sure where you'd use the extra 4' of PVC tubing your instructions called for, but happy I decided to chance it and only get 20 feet.<br> <br> For tank holders, I got two 4&quot; PVC coupling sections, and cut them down the middle horizontall and vertically, giving me 8 possible tank holders. I drilled out three holes like you did to attach them to the PVC/dowel combo (nice trick with the dowel btw, very clever!), and after leaving just the two outer screws in (not the third), the 4&quot; diameter spread out slightly wider, since 68ci/4000psi compressed air tanks are 4.3&quot; in diameter.&nbsp;<br> <br> I picked up some pipe clamps which came in 4 pieces (two sets, top/bottom), and folded the 'flaps' over. I used a steel drill bit to drill out a single hole, put a nut/bolt combination on them, and fastened everything tightly. I bought a bottle of &quot;liquid electrical tape&quot; but decided against it and just&nbsp;covered them with the same 3/4&quot; weather stripping I used on the tank holders. I had seen some plastic-coated tool clips for about $2 each for hanging tools on a wall, but decided they were too expensive.<br> <br> The weather stripping is nice and padded, though the 4&quot; PVC was slightly wider (almost 2&quot; wide) than two strips of the 3/4&quot; stripping I bought (should have bought 1&quot; stripping).<br> <br> The only addition I'm going to make is to pick up something to cap the ends of the mask bars. Either 6 more caps, or 30-degree elbows for a 'hook' so masks don't slide off since the bars are slightly shorter than the instructions called for.<br> <br> Can't wait to try it out this weekend.<br> <br> <a href="https://lh3.googleusercontent.com/-wPFns6w-O70/ThJhZ8cQK8I/AAAAAAAABRo/vmQNyiY1v1M/s1024/IMG_20110704_175612.jpg ">Full-size image</a><br> <br>
Thanks for the feed back, Looks great. Since writing the original instructions I have since made two more racks and offered suggestions for alternate parts from the original. See customizing step. :-) I added caps to the ends of the mask holders as well since I noticed the masks fell of too easily. The original estimate for how much pipe to get was just a guess since not everyone will cut the parts from the right length of pipe and could run short. :-) Good luck with your gun\mask rack and hope to see you in the field someday.
If you check out Step 8 where I make some mods to the design. Those tank holders don't fit the tank snug. Basically the rubberized coating holds the tank in place. It works better when they have a tank cover on the HPA bottle but good enough grip for when they don't. Most player are running a 68/4500 tank so they are all about the same size. The CO2 tanks if they are 20oz tanks fit in there because they are smaller than the HPA tanks. This rack works with most paintball guns. There are some Milsim ones out there that won't fit but that is more about the length and shape of the marker than the tank. HTH.
I had started making notes on how to cut the 10' lengths to where I literally ended up with 1&quot; left over from two 10' pipes. I'll see if I can find that and post it up here as a reply. If I have some free time, I'll see if I can go make a list of which areas I found everything, actual costs, etc.<br><br>In general, Home Depot staff were insanely helpful to find parts once I described what it was I was trying to build. A few of the older guys looked at me funny about how to find something to hold the tanks. They sell strips of sheet metal which you could bend, but that would require (a) bending the steel, (b) not slicing your fingers in the process, and (c) maintaining the shape.<br><br>I also recommend picking up the 20' of PVC tubing LAST so you have have to wheel that stuff all over the store.
Quick follow-up ... the instructions called for a 5/8&quot; dowel rod, but I used a 3/4&quot; dowel rod which fit way more snugly within the 3/4&quot; PVC tube. Less sliding around while getting things screwed in where they belonged, etc.
About This Instructable
31,736views
47favorites
License:
More by Byoung4now:Gun Safe Led Lighting project:  Dual color with motion detector Honey Jack Tiki Torch Deck Brackets Paintball Pod Quick Loader Tool Box Attachment.
Add instructable to:
