Introduction: DIY Heart Ring With Binding Wire
Have you ever wanted to present someone a very special gift and wondered what to gift? There’s no better option than a Handmade Ring. You can make a ring easily from Binding Wire.
Binding Wire is used for the purpose of packaging in various industries. Binding Wire is one of the finest that is available in the market.
In this Instructable, I’ll show you How to make a heart ring from binding wire.
Step 1: Things You Need
- Stainless Steel Binding Wire
- Cutting Pliers
- Nose Pliers
- A Creative Mind
Step 2: #Cut Them
Once you have all the things at hands reach, it’s time to cut out the required length of the binding wire. Based on the size of the hand, the length will vary.
Now also remember that you have to have enough length to bend the wire into a heart. Use a cutting pliers to cut the wire carefully.
Step 3: #Make It
Now using the nose pliers, bend the wire at one end in the shape of a heart. Refer the above images for better understanding of how to bend the wire.
Now after completion of the heart, bend the remaining part of the wire in a circular fashion and complete the ring. You can also make a small loop on the other end to make it look more better.
Step 4: #Done
After you complete making the ring you can clean off the ring using wiping alcohol.
Once completed, you can present your DIY Handmade Ring in a Ring Box.
Makerspace Contest 2017
