Remove these ads by
Signing UpStep 1"Make an LED flashlight out of ..."
"Make an LED flashlight out of ...":
an Altoids container!
a Tic Tac container!
a Mini Altoids container!
an empty 9 volt battery container!
an Altoids gum container!
an empty film canister!
a used wad of toilet paper!
Well, this one is DIFFERENT. It's difficult, dangerous, and just plain time-consuming. So don't try this at home, unless your middle name is Danger. And you first name is Nerd. So, you're still interested? Ok, then. Step into the light.
its alot bro
BTW, microcontrollers probably cost less that you think. This one cost me about 60 cents.
(I have a good basic training in microprocessors, it would be nice to find a teaching community and coding tips. As the PIC and PICAXE system is well supported as an educational tool, it seems like a good one to get one's teeth into.)
Microchip has fairly active forums if you have specific questions. But to formulate a specific question, you'll have to read the datasheet. :)
As far as learning assembly coding tricks, Micochip has dev boards and tutorials for various devices. If you can follow the schematics and/or make your own boards, you can then download the turorials for free. They'll cover some basic programming tricks, such as making delays, using interrupts, how to make macros and subroutines, etc.
her maiden name was schmidt. quite unoriginal.
Mejor con in poco de funda termoretractil
what does the title mean?
Lwts just say sparks flew, and rather thick metal glowed.
It's far better to use a variable output supply and an ammeter, or to use some active current limiting.. or even passive current limiting. A 5 ohm 5 watt resistor in series with the battery would pretty much ensure a safe current limit for a 3 cell battery charged at a fixed 12.6V. But it would also increase the total charge time by quite a bit.
