6 Sheet Paper Box
4,028
14
8
Published
Introduction: 6 Sheet Paper Box
About: i like to build things out of junk and i want to be an inventer as a profession
this is just a sturdy box that uses 6 sheets of paper.
Step 1: Getting Started
materials
6 sheets of paper (i used notebook but construction is better)
some free time
in this step i will show you the first and second folds to making the 6 units.
1st step: follow picture
2nd step: flip over and fold like the pic
WARNING make sure you fold them all in the same direction or the will not fit together at the end.
Step 2: 3rd & 4th Step
the rest of the steps exept for the last few.
just use the pitures
Step 3: Finishin the Unit
these are the last steps
use pics to help
fold the triangle under long flap
do the same with the other and then fold the flaps up.
thats one unit fineshed 5 more to go
Step 4: Building the Cube
the construction of the cube is pretty self explanitory.
if you have any questions just ask but please dont critisise
PLEASE USE THE REPLY BUTTON when i answer your qeustions it helps me keep up with your comments
Step 5: BONUS
BONUS if u like you can come up with your own shapes check out the pic.
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    8 Comments
    Why did i find this in the USB section? You should probably change that.
    because this one has a unique design and if you make multiple units you can make bigger boxes
    damn.. dude.. ur instructions are not very clear.. i figured it out thoug. The point u should improve is the folding instruction! But nice box ;> thanks
    it doesnt work. step 2 the paper is to short to do the 2 triangle folds.
    in that step all i did was fold the paper into 1 triangle and then you have the leftover tab so that is were step 2 comes in. all that you are doing in step 2 is folding that tab backwards
    nothing to do with knex.
    I reccomed you remove knex from the keywords.
    "Knex"???
