3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
6 under-appreciated things about Petroleum Jelly
Every house has a jar of good ol' Petroleum Jelly. Yet this jelly is very under appreciated for all of it's great uses.
Here are a few of the most interesting!
Step 1Loosening Stuck Drawers
Have a stuck drawer? Use petroleum jelly to prevent it from sticking and make the drawer move smoother.
163 comments
1-40 of 163next »
Jul 20, 2010. 1:26 AMxenograftsoul says:
It isn't clear how petroleum jelly will help you light a fire. It isn't easily flammable, a.k.a. will not light with a regular lighter.
Mar 25, 2012. 2:20 AMrudedude119 says:
it will burn you just need to put it on cotton wool also nail varnish remover burns really well on cotton wool
Jun 23, 2011. 11:38 AMlalexander says:
rub it into cotton ball. as much as it will take. it can be lit with a flint even after dunking in water. squeeze water out, pull it apart so tiny threads are exposed, strike flint and it goes up easy. wind proof. far better than magnesium shavings. burns for at least 5 min and wont blow out. place the cotton ball on top of a tea candle and itll burn for near an hour. it melts the wax and the cotton ball acts like a oversized wick. with no wind, the flame can get 8 inches tall. place the whole thing under wet wood and you can get water soaked wood to burn. vaseline, cotton ball and a teacandle is the best firestarter ive ever found.
Jul 20, 2010. 9:55 PMPyromaniacDaniel says:
Its like a candle. try to light the wax alone and all that will happen is it melts and drips away but when you add a wick, the wick soaks up the melting wax and holds it in the heat to become a gas and then that gas burns. So to get the petroleum jelly to light you need a wick material like leaves, bark, and small twigs. To see just how flammable petroleum jelly really is in a small metal cup melt then boil and light a small quantity of it. It burns rather nicely. Old socks work fabulously for wicking materials and can be wrapped around a stick for a torch.
Mar 15, 2012. 8:45 AMTakelababy says:
A skin specialist recommended liberal use of petroleum jelly on the face and lips as a defence against drying cold winter winds. My horses get it slathered on their nether parts during the biting bug season. It lasts about 3 days and sure helps the horses.
Jan 29, 2012. 11:18 AMEkdog says:
@Cerafem: There are cases of people smoking into their 90's. Does that mean tobacco is harmless? I don't think so.
Dec 11, 2011. 1:10 PMtedgar says:
Vaseline.. essential when racing motorcycles across the desert or cross-country for hours at a time.. Also called "crack-wax" .. save yourself terrible chafing by applying liberally between cheeks ( nearer the top ) to prevent a roadrash like condition that will make subsequent days of riding hell on wheels-
Dec 23, 2011. 2:28 AMpunkhead58 says:
I second this.
Jul 18, 2010. 8:20 AMBobmanJCT says:
I like how you recommend putting it in an electrical connection, as well as using it as a fire starter. Seems clever, that.
Sep 9, 2010. 7:48 PMcdousley says:
thats what i thought. But i dont think thats where the hot wire goes
Dec 14, 2011. 7:11 PM-max- says:
it doesnt matter which is which. they both carry a current. its just that the live wire floats at around 120v compared to ground. while the neutral doesn't carry a current if connected a load between it and ground.
SO, when their is a load across the live and neutral, an AC current will flow.
Dec 11, 2011. 7:32 AMA_Steingrube says:
This is a HUGE fire hazard. If you want to "lube" your light bulbs, there is nonflammable, conductive grease that you should use. Petroleum jelly is often found in survival kits as a fire-starter for a reason. Placing it in a very hot environment that is prone to sparks is a very bad idea.
Dec 14, 2011. 7:07 PM-max- says:
i hardly believe it hegs hot enough to start fire and it wont spark. but its possible.
and NEVER use conductive grease, the electricity will go through that and heat it up and not go into the lightbulb.
Jul 20, 2010. 9:29 AMtchronin says:
Ever heard of "popularly accepted theory” Lookup layers of the earth and most all articles present it as fact making no mention that is "popularly accepted theory". Where does oil come from? What is coming, Global warming or Ice age? We believe what we want when it suits us. Arguing back and forth pretending to have answers is both pointless and ridiculous. "The law of conservation of mass, also known as principle of mass/matter conservation is that the mass of a closed system (in the sense of a completely isolated system) will remain constant over time. The mass of an isolated system cannot be changed as a result of processes acting inside the system. A similar statement is that mass cannot be created/destroyed, although it may be rearranged in space, and changed into different types of particles. This implies that for any chemical process in a closed system, the mass of the reactants must equal the mass of the products." So everything "man-made" is in fact natural, if not where would we get the ingrediants. Now, do what we do best and dismiss my comments and insert your own reality and continue to believe that you are correct in your opinion. Thank you for the tips on howto use the "madmade\natural" substance know as Petroleum jelly. It also makes good wheel bearing grease for skateboards and rollerblades.
Dec 11, 2011. 12:17 PMgnach says:
You failed to mention that petroleum is also organic, as in chemistry, so no problem ;)
Jul 20, 2010. 3:23 PMdagenius says:
That law has nothing to do with the instructable... besides for the fact that vaseling is made of petroleum.
Jul 20, 2010. 10:33 AMSpokehedz says:
What is this... I don't even...
Dec 11, 2011. 10:09 AMmarxdarx says:
I just use a quick spray of WD40 on my hinges.
Jul 15, 2010. 4:00 PMShelby S says:
1) WD-40! :D 2) Is that safe? 3) How about just having no curtain at all? :P 4) WD-40! :D 5) Is it safe to cook food on a fire started with this? 6) I really need some chapstick. Time to whip out the vaseline.
Jul 18, 2010. 10:36 AMAutumnJazz says:
WD-40 isn't a lubricant, and it shouldn't be used as such. Use silicon lubricant or something.
Apr 11, 2011. 12:29 AMnnnoooiiissseee says:
I guess it all depends on what your trying to lube up. I prefer baby oil...
Jul 15, 2010. 4:06 PMsassy8girl says:
for 5 i think it is safe because petroleum jelly is used in lip balms and if it was toxic it wouldn't be used for it (^__^)
Jul 18, 2010. 8:42 AMeasyrider1 says:
you may want to read the new independent findings on the dangers of using commercially sold lipsticks at www.NaturalNews.com it turns out lipstick is not really safe to use. if you knew your parents were unknowingly using something that would adversely affect them in the long run would you want them to be informed so they could make an intelligent decision? they may want the same for you. don't put anything on your body that isn't with out a doubt safe to put in your body.go organic, it's only natural.
Jul 15, 2010. 5:05 PMmr.incredible says:
The finder of the original Vaseline or petroleum coak, use to eat a table spoon a day from the time he started hawking it until he died in his late 80's.
Jul 15, 2010. 4:55 PMShelby S says:
Would you eat lip balm?
Jul 18, 2010. 6:16 AMcrickle321 says:
When lip balm is on your lips, you essentially are eating small amounts when you eat food or just licking your lips. It doesn't seem a lot until you get to the end of the tube and wonder where it all went...
Jul 15, 2010. 6:50 PMmr.incredible says:
I didn't say I would. Bleeuch!
Jul 16, 2010. 7:07 AMdscotthep says:
Put a half teaspoon full of petroleum jelly on your finger, let your cat lick it off. Repeat monthly. No more hairballs!
Apr 11, 2011. 12:23 AMnnnoooiiissseee says:
I tried that on my wife. It didn't work.
Jul 18, 2010. 6:14 PMwocket says:
and no more cat
Jul 18, 2010. 6:18 AMlazemaple says:
Olive oil or butter works as well and wont' give kitty cancer. Vaseline is a petroleum product.
Jul 18, 2010. 10:37 AMAutumnJazz says:
And nothing has shown it to be a carcinogen.
Sep 30, 2010. 7:07 AMlazemaple says:
The Environmental Working Group database says otherwise
http://www.cosmeticsdatabase.com/ingredient.php?ingred06=703977
http://www.ncbi.nlm.nih.gov/sites/entrez?cmd=PureSearch&db=pubmed&term=%288012-95-1[RN]%20OR%20%22MINERAL%20OIL%22[TW]%20OR%20%22*MINERAL%20OIL%22[TW]%20OR%20%22DEOBASE%22[TW]%20OR%20%22HEAVY%20MINERAL%20OIL%22[TW]%20OR%20%22HYDROCARBON%20OILS%22[TW]%20OR%20%22LIGHT%20MINERAL%20OIL%22[TW]%20OR%20%22LIQUID%20PARAFFIN%22[TW]%20OR%20%22LIQUID%20PETROLATUM%22[TW]%20OR%20%22PARAFFIN%20OIL%22[TW]%20OR%20%22PARAFFIN%20OILS%22[TW]%20OR%20%22PARAFFINUM%20LIQUIDUM%22[TW]%20OR%20%22PROLATUM%20OIL%22[TW]%20OR%20%22WHITE%20MINERAL%20OIL%2C%20PETROLEUM%22[TW]%20OR%20%22MINERAL%20OIL%22[TW]%20OR%20%22PETROLEUM%20WHITE%20MINERAL%20OIL%22[TW]%20OR%20%22MINERAL%20OIL%20HYDROCARBON%20SOLVENT%20%28PETROLEUM%29%3B%20MINERAL%20OIL%20%28SATURATED%20PARRAFIN%20OIL%29%22[TW]%20OR%20%22ADEPSINE%20OIL%22[TW]%20OR%20%22ALBOLINE%22[TW]%20OR%20%22BAYOL%2055%22[TW]%20OR%20%22BAYOL%20F%22[TW]%20OR%20%22BLANDLUBE%22[TW]%20OR%20%22CRYSTOL%20325%22[TW]%20OR%20%22CRYSTOSOL%22[TW]%20OR%20%22GLYMOL%22[TW]%20OR%20%22KONDREMUL%22[TW]%20OR%20%22LIQUID%20PARAFFIN%22[TW]%20OR%20%22NEO-CULTOL%22[TW]%20OR%20%22NUJOL%22[TW]%20OR%20%22OIL%20MIST%2C%20MINERAL%22[TW]%20OR%20%22OIL%20MIST%2C%20MINERAL%20%28ACGIH%3AOSHA%29%22[TW]%20OR%20%22PARAFFIN%20OIL%22[TW]%20OR%20%22PAROLEINE%22[TW]%20OR%20%22PETROGALAR%22[TW]%20OR%20%22PRIMOL%20355%22[TW]%20OR%20%22PRIMOL%20D%22[TW]%20OR%20%22SAXOL%22[TW]%20OR%20%22USP%20MINERAL%20OIL%22[TW]%20%29%20%20AND%20%28*toxic*%20OR%20cosmet*%20OR%20derm*%20OR%20irritation%20OR%20sensiti*%20OR%20%22personal%20care%20products%22%20OR%20skin%20OR%20gavage%20OR%20mutagen*%20OR%20carcinogen*%20OR%20%22biological%20activity%22%29
Jul 18, 2010. 2:58 PMlazemaple says:
With the exception of cats who cannot metabolize petroleum by products like vaseline. If a child 30 pounds plus can't ingest it, how is it safe for a 10 pound cat? US National Library of Medicine Household Products Database http://hpd.nlm.nih.gov/cgi-bin/household/brands?tbl=brands&id=3004039&query=vaseline&searchas=TblBrands Product Name: Vaseline Petroleum Jelly-Old Product Warnings: For external use only. Not to be applied over deep or puncture wounds, infections or lacerations. If redness or swelling develops, consult a physician promptly. Keep out of reach of children.
Dec 12, 2011. 9:00 AMrafain says:
I've read all your links above and none of then suggest any kind of danger by ingestion, nor that it is a carcinogen. We're talking about small quantities, in larger amounts everything is deadly even water!
Dec 12, 2011. 8:28 PMlazemaple says:
Clearly you have read none of it and for some reason the relationship between petroleum from right on the product label and petrochemicals has gone right over your head!
Good lip balm made with quality ingredients is the easiest thing in the world to make and for those who don't wish to smear car lube on their lips here is a nice one especially if flavoured with peppermint oil and virgin coconut oil is used.
2tsp coconut oil
1 tsp beeswax
1 vitamin E capsule
Melt together and pour into a container, allow to cool.
Dec 12, 2011. 10:56 AMlazemaple says:
if you want to spread engine grease on your lips I guess that's your prerogative.
I'd rather use organic olive oil and beeswax thanks all the same.
Dec 12, 2011. 12:38 PMrafain says:
I think your prerogative is to belive whatever you read.
We weren't talking about engine grease but petrolatum and if you'll take a moment to read the links you've supplied you'll notice that NONE of them points in conclusive that petrolatum is carcinogen. Even if you read carefully one of your links stated below you'll notice it: "Petrolatum - Impurities in Petroleum Jelly or commonly known as Vaseline, under suspicion as a carcinogen in Breast Cancer - Petrolatum Banned in products ..." It aimes to Impurities in Petroleum Jelly not the Jelly itself. I could tell you myself that not all Petroleum Products are carcinogens (only a very small portion of it) since I've being involved in scientific studies within this kind of products and cancer for the last decade in an internationally renowned university. And Petrolatum is among the safest.
BTW: Google "life in mars" result in 503,000,000 hits!!!! LOL
Dec 12, 2011. 10:54 AMlazemaple says:
Selective Vision?
Google 'petroleum jelly cancer' results in 350,000 hits!
here are a couple of them
Petrolatum - Petroleum Jelly - Cancer and Health Concerns
www.health-report.co.uk/petroleum_petrolatum_health_concerns.htm
Petroleum jelly possible cancer risk | Green and Chic
greenandchic.com/blog/petroleum-jelly-possible-cancer-risk
Rating: 9/10 - 4 reviews
16 Sep 2008 – Petroleum jelly possible cancer risk in the news vaseline, dry skin, acne, hair care, cancer, lotions, petro oil propylene glycol.
Jul 24, 2010. 10:59 PMrcowgirl_6 says:
Do NOT use petroleum jelly on lips, its very bad to ingest. You lick lips and you ingested it.
1-40 of 163next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
397
Author:frenzy
I'm the QA engineer here at instructables. I make cool projects in between testing instructables.com to make sure it works awesomely. Give me your bugs!
