$60 Laser Engraver / Cutter
I drool on my keyboard when I look at those fancy laser cutter/engravers that cost $$thousands, so I figured out how to make one for $60. That's right -- 60 bucks.
My design is not EXACTLY like the multi-$1,000 models, but it will let you do a lot of the same work. Figure on 'manual' rather than 'computer-operated'. This means you don't have to learn CAD, or even have a computer. It can also be used as a portable (bonus!). Did I mention it only costs $60?
When I saw the cutting laser that Stephanie Maksylewich made, I knew all that was missing was some way to control where it points and burns, and a variable AC power supply to control the intensity. See the video here.
I decided to mount a cutting laser on a pantograph, (and see below) used for centuries to copy, enlarge, and shrink an existing drawing. But instead of a pencil lead making the duplicate, we'll use the laser to cut or engrave.
I built a variable power supply out of 10 simple electrical pieces, and a pantograph out of four yardsticks and some nuts and bolts.
Remember to always treat this device with respect -- it's an industrial-strength handheld power tool, even if it looks homebrewed.
Step 1First things first
First, read through this entire instructable before buying or assembling anything.
I'm using mine to prototype a new product, and I couldn't justify putting $$thousands$$ on my credit card to test my idea. Maybe you'll come up with a way to make some cash. If you can afford 60 bucks and some time, you might be in the laser engraving and cutting business next week (it takes a few days for parts to arrive in the mail).
Important!! You must be over 18. This is NOT a toy. It'sa powerful industrial-strength tool. Adults only. Period. It burns holes through plastic fast. You should probably have a fire extinguisher nearby, which you probably already own if you're up for this kind of mischief.
You can easily dial the power down and just etch the surface of your stuff. Get plenty of practice on materials you don't need <<before>> you etch your buddy's laptop.
There's a big learning curve on the $10,000 models, but at least they come with lots of instructions. These are my instructions . . .
I am not responsible for anything you (or your assigns) damage, burn or toast for any reason. Not responsible. Et cetera. Not responsible.
Maybe some kind readers will enlighten all of us with their experience and knowledge in Forum or Comments sections describing some tricks of the trade for using laser cutter / engravers. (Other than, "Get a real one," please.) This does not include drawing toast pictures on bread.
There's nothing difficult, no special tools, and not a whole lot of skill involved. It's actually fiendishly simple. I've put in a lot of details, so this instructable looks longer than it really is.
Use common sense, and safety first.
Let's engrave some stuff!
102 comments
1-40 of 102next »
Aug 12, 2011. 9:57 PMnikhilpatankar says:
hello sir,its wonderful bt i m from india n v have 230volts 50hz power supply.........can u plz mail me a circuit accordingly on my email id nikhil.patankar390@gmail.com
with all specification of laser diode........
thanks alot
May 31, 2011. 2:13 PMPizzapie500 says:
Can this cut paper or will it burn?
Jan 3, 2011. 3:32 PMSsslouter says:
how do I know which leg is VIn, VOut or VAdj? I think I know but I'd rather not take chances.
Nov 12, 2010. 1:04 AMHardwyre says:
DVD burner lasers have a max rating of less than 300 milliwatts, how can you claim this will be as strong as industrial lasers?
Is this going to be able to cut stainless steel? Aluminum? At least acrylic and plastic sheet?
Dec 19, 2007. 4:40 PMTimextoxlive says:
this wouldnt work. Ive made class 3b lasers (a little stronger output than the DVD burner diode). It will SLOWLY cut electrical tape, or light black matches. but as far a burning anything that isnt thin and black, no chance in hell. sorry man, good idea, but the diode just isnt powerful enough.
Aug 20, 2010. 6:01 AMhubi says:
This will work, but not for a long time. first mistake, laserdiodes don´t last long if they are voltage driven, it´s better to use a constant current source. second, a dvd laserdiode from a 16x dvd writer will not last more than 150mA in that case, if properly cooled by a good heatsink or a TEC you can achieve 250mA. but 500mA or more will cause sudden death of the diode. also laserdiodes don´t like short voltage spikes, they can cause a decrease in output up to the death of the diode and in your supply there is no protection against those spikes. if you really want to burn morethan only black tape, you need more power. I used a cheap 2W IR(808nm) Laserdiode with constant current source. to see the beam for focussing, one can use a digitalcam.
Sep 19, 2010. 12:06 PMcarlos flores says:
Estimado HuBi no entendi bien lo de la camara pudieras extensor digital Mas El tema
Jul 10, 2010. 8:12 PMyespotato says:
it does work i did it.
Apr 17, 2009. 11:25 AMcovey12 says:
ive used dvd lasers to burn everything from balloons to balsa wood
Aug 24, 2010. 5:12 PMSsslouter says:
would it be able to cut cardboard?
Aug 8, 2010. 5:23 AMshubham garg says:
What are the things that can be burned with the laser cutter as this?
Mar 31, 2010. 1:26 PMpufferfish9108 says:
how do u do the dvd burner thing? is there a link?
Jul 24, 2010. 9:46 AMArmchair Pyro says:
first page where it says "Stephanie Maksylewich" 1) click on it 2) hover mouse over "high-tech stuff" 3) then "lasers" 4) then click on "DVD Laser" or similar
Jun 7, 2010. 10:07 PMPainTrane says:
Could I use a 6V battery to power this laser? He stated that the laser only uses 3.2V max. So would a 6V battery dropped to 3.2V work okay? Thanks.
Apr 9, 2010. 7:17 PMWV_Kokamo_Joe says:
 I want to say to i m legend that YOUR Comment on this man's hard work is very rude and I think is not positive or constructive. Lets See your small converging lens on your laser cutter. anyone else want to see it? I know I do.....
Jan 25, 2010. 11:07 AMrhino21 says:
Is there any way to protect your eyes or rest of your body from the laser burning you or blinding you? Would a welding mask work?
Feb 25, 2010. 9:43 AMmmcnickle says:
Welding mask is no good.
You need to buy the correct laser googles i.e. the googles match the wavelength of the laser you are using.
Mar 19, 2010. 3:36 PMttrat says:
 lol "googles"
Feb 25, 2010. 11:08 AMrhino21 says:
OK. Cool. My dad just told me he has some laser goggles. Thanks!
May 28, 2010. 10:32 AMiBurn says:
 They won't work if they're not made for the same wavelength as the laser they're supposed to protect you from.
Apr 16, 2011. 10:46 AManode505 says:
Maybe, maybe not. If the laser can cut it, then the glasses would be safe as a rule of thumb. If it cuts it, then its absorbing the energy, not transmitting it through. The 1500W - 6000W CO2 lasers I service use standard plexiglass windows. Saves ya no prob, but granted that 10,600 nM
But yes i agree, do some research and make sure they 'fit' your laser.
Jan 21, 2010. 5:42 PMKnexFreek says:
 AWESOME!!!!!!
Dec 13, 2009. 8:49 PMthingygoboom says:
An incredibly good idea and Instructable.
However I don't trust myself working on anything like that.
Jul 11, 2007. 2:39 PMmadgyver says:
What's been said about the laser and its output so far is quite right. The Laser will not be able to "cut" anything thicker then 0.25mm.
Here you can see mine:
http://www.youtube.com/watch?v=wXfRSjHgtxs
But it shoud be nice or engraving stuff, if you move and hold it precise of course.
Jul 14, 2007. 8:39 AMdrcrash says:
Would a DVD laser cut foam? (Like pink or blue extruded polystyrene insulation foam?) That could actually be very useful; if you can cut a shape in foam, you can easily mold and cast it, or put a hard surface on it and vacuum form over it. Foam is a bunch of thin-walled bubbles, so cutting through it is like cutting through a bunch of very thin layers of plastic separated by air. I don't know whether to expect that to work, though. I don't know if the frequencies put out by DVD lasers are absorbed well by the plastics that foams are made out of. (And maybe not---I guess they're designed to pass through the polycarbonate plastic that DVD's are made out of. Unless polystyrene has an absorption peak there, where polycarbonate apparently doesn't, the laser beam may just go through a bunch of layers without cutting any of them.) I notice that on your YouTube video, you're engraving a dark-colored plastic. Does it work with light-colored plastic, or does to much of the beam pass through or reflect off?
Nov 10, 2009. 8:21 AMquasi44 says:
With a foam, the integrity of the beam is compromised from the shape of the mildly refracting surface of the bubbles in it, causing near instant heat in an area where random gases are expanded with the beam, causing little mini explosions that subtract from the accuracy of the cut before the beam actually gets there. Nothing wrong with your idea except choice of medium for your mold.
Jul 18, 2007. 7:47 AMmadgyver says:
The Laser will cut foam, but it will also take a lot of time. Doing it with a knive is faster und more precise. The laser melts and then burns ist away. Real laser engravers use lasers, so powerfull they actually vaporise material away, yielding a nice and clean cut. Indeed those laser only work on dark plastics and dark woods.
Aug 24, 2007. 5:03 PMRybin says:
so what would it take for me to make a hand-held laser cutter that can penetrate say... 1/8" corrugated steel? just curious...
Nov 10, 2009. 8:05 AMquasi44 says:
The problem with a laser is that for it to be useful, you must be able to both contain, and control it. Lasers can be optically pumped using very small amounts of power to near limitless coherence...provided your lenses and mirrors are made precisely enough, and placed precisely enough....but then you MUST be able to provide an environment for it, free of stuff like dust, flammable gases like oxygen and hydrogen, and the mirrors; not precisely equal, one of them must allow the pumped beam pass...understand, people, lasers are neat, but be VERY serious when experimenting. The consequences are.
Nov 8, 2009. 5:47 PMPikminRed says:
"When your laser stuff arrives, read every word in the next section all the way to the end. Out loud. Twice. Don't cheat -- I'm watching you. This laser will immediately BURN AND CUT anything you put in front of it faster than a hot knife through soft butter. And, a laser is a light beam, so it will REFLECT OFF OF ANYTHING SHINY OR REFLECTIVE AND THEN BURN WHATEVER ELSE IS NOW IN ITS WAY. You're not going to cut shiny foil or anything else that reflects light unless you want a quick trip to the Emergency Room."
Lol I'm Still following your warnings but. That. That was funny.
Nov 4, 2009. 3:54 PMjordan98 says:
the pick your power supply page is doing the same
Nov 4, 2009. 3:53 PMjordan98 says:
could you please put a list of the materials and tools needed in the intro because whenever i try to view them it shows but the text that you put in is missing
Oct 16, 2009. 8:35 AMrrp9 says:
This is an excellent instructable.  I just have one comment:  If you place a stylus or laser in the lower middle joint as shown, the only motion possible at this point is to swing back and forth in an arc.  Because one of the segments is pinned at the other end, swinging (rotating around the pin) is all it can do....
Oct 16, 2009. 8:48 AMrrp9 says:
Oops!  After looking at this a little further, I must qualify my previous comment.  This IS a good instructable in the level of detail, instructions, etc.  However, it is not a functional device as designed.  Laser cutting with bolts through yardsticks just will not work.  Hence the lack of any photos of the assembled and functional device or any samples of its output....
Jul 16, 2009. 7:20 PMBriguy9 says:
ah, the pantograph, a century-old invention. changing something like this that's tried and true would be like trying to reinvent the wheel, right?
Aug 8, 2009. 3:14 PMTommyhzy says:
Step 9 and 10: HOLY EXCREMENT that is a LOT of typing. 5 stars because you put so much time and dedication trying to teach other DIYers how to save about $6000 and get a nice milkshake :)
May 28, 2009. 11:15 AMmatroska says:
Wow! This instructable was the missing part for my laser etcher project! I was too planing to build a DIY laser etcher machine, only mine would be computer controlled. However I knew nuts about lasers, and I really wasen't sure a DVD burner diode could do the job. I even had no clue about how to supply it. Well, now it's solved! I have an old PC power supply, with many output ratings, varying from 1A to 15A (!), and from 3.5V to 12V, however I wouldn't know how to use it. I also have an old laptop adapter, rated around 17V I think, I forgot the amperage. I do have a question... how it is possible to supply, say the 12V you mentioned, if the diode will burn out at more than 3,25V? Other than this, thank you, you are a true genious and my cheap DIY will be done with your help :)
May 21, 2009. 11:44 AMMaddMann says:
I don't know enough about it to say whether or not it will burn anything, but I'm going to give it a try anyway; the diode burns DVD's why not paper, wood, etc? Increasing its intensity with a magnifying/focusing lens can only help. If it does work I'm thinking I'll build a CNC from one of the Instructables and slap this laser into it - set it and go! I'm also thinking that some protective laser safety goggles formed around the base of the laser would greatly increase the safety of this. Nice instructable, by the way!
Apr 23, 2009. 2:57 PMcuchulain92 says:
Has anyone considered focusing the beams from multiple emitters to a single point?
1-40 of 102next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:cgosh
