I had a brainfart this morning that transformed a $10 spare scrap of plywood into a really cool 5' tall, designery bookcase that some yuppie idiot would probably pay a few hundred for.
Warning: this procedure involves extensive lame woodworking techniques such as glueing and stapling with nailguns. If you're a dovetail joint purist, you probably don't want to read any further.
Step 1: Ingredients
Tools you will need:
- a table saw
- a nail gun
Material you will need:
- at least a quarter of a plywood sheet, 96" long x 12" wide x 3/4" thick.
- at least 60 1.25" brads for the nail gun
- wood glue
- sand paper
- pabst blue ribbon, to help you channel your inner bubba.
Note: User earay indicates that MDF might be a better substitute for plywood, as it is cheaper and easier to paint when complete.
Step 2: Cut boards
In this step, we're going to create our 16 6" x 12" boards.
How you create these boards isn't important. Keeping to the exact specified dimensions isn't necessary either. What is important is that all the boards be identical to fairly tight tolerances. One way to get there is the following procedure for cutting these boards out of a quarter of a 4' x 8' plywood sheet.
First, cut a 12" x 96" plank out of your plywood board. Set the rip fence of your table saw at 12" and pass the board through the saw once. You will only use that plank for this project -- use the remaining 3/4 of that board for something else (or else, build 3 more of these bookcases). (Actually, feel free to adjust this width to your taste).
Next, adjust the rip fence of your table saw to a little bit less than 6". Rotate the plank you just created 90 degrees, and subdivide it into sixteen identical 6" x 12" boards. Remember to pass the last board through the table saw, just to ensure that it's exactly the same size as the others.
Also: always use a push stick when moving wood through the table saw! I don't want to hear no complaints from any of you fingerless whiners. "I used to program computers for a living." "I was an artist" Wah wah wah. Use a push stick.
Step 3: Assembly: layer 1
Pick three boards, and attach them together to form the first layer of the bookcase, as shown in the diagram below.
To attach the boards, first lay down a line of glue. Then, holding the boards in place, fire brads up through the bottom of the bottom board into the edge of the joining board. These brads will staple the joint in place while the glue dries. About 3-5 brads per board should be sufficient.
Note that the vertical boards are stacked on top of the base board -- not alongside it.
Grevious bodily harm warning: it's easy to "miss" when firing the brads up through the bottom board into the edge of the vertical board. Make sure that your fingers aren't anywhere near the place where a brad might unexpected appear. Protect your fingers! You only get ten of them, and then they're all gone forever.
Step 4: Assembly: layer 2
Now, place two lines of wood glue atop the vertical boards from step 1, and glue another horizontal board on top to make a box. Fire some brads in from the top to pin the board in place while the glue dries.
Once the board is in place, glue two new vertical boards atop the horizontal one. In the previous step, the two vertical boards were placed along the left edge and the back-right edge. This time, place the boards along the right edge and the back-left edge. This should give you clearance to place the nailgun beneath the newly glue boards, and to fire brads up through the horizontal board into the vertical boards, pinning those boards in place.
Step 5: Assembly: layers 3, 4, and 5.
Repeat the previous step for the next three layers, alternating the placement of the vertical boards for each layer. In this manner, an "S" shaped pattern should emerge.
Step 6: Assembly: Put a lid on it.
Finally, take your last remaining board, glue it to the top of your structuer, and pin it in place with brads.
Step 7: Finishing
Wait for the glue to dry.
Sand the rough edges off the plywood.
Finish the bookcase to taste (stain, seal, paint, etc.).
Some variations:
- turn the bookcase on it's side, and now it's a bookshelf suitable for mounting on your wall!
- build a bunch of these units and stack them together. It's modular!
1-40 of 137Next »
dejure says: Jan 22, 2013. 10:10 AM
I really like your design. It's simple, looks very nice and appears it should tolerate being moved while laid on its side. Since this is something which could be enjoyed for years of use, we'd do well to make sure we follow the instructions (e.g., keep joints tight and use glue).
I thought this was a nice enough project, many would might want to consider adding wood banding (e.g., 1/8" or 1/4" strips cut to the wide of the plywood) to cover the plywood edges. Alternately, some might prefer 1/2" round (doweling cut in half) or other molding, according to their tastes and preferences.
. If the joints are kept tight and everything were glued, the only weak spot of the design [when moved, suc (e.g., laid and carried on its side) should be minimized
timlawyer says: Feb 8, 2006. 11:26 AM
WARNING - DO NOT USE THE RIP FENCE to make the series of 6inch cuts shown here. Use a miter or cross cut saw guide. The way it is described here, you are essentially cutting off 6inch ends from a long rectangle that is perpendicular to the saw blade. DO NOT USE THE RIP FENCE because if the cut off piece pinches between the rip fence and the very back of your saw blade - THE 6inch CUT OFF WILL FLY BACK AT YOU AT OVER 100MPH - ENOUGH TO KILL YOU.
alanemartin in reply to timlawyerOct 6, 2011. 1:44 PM
A properly equipped table saw should have a splitter behind the blade to help prevent this very issue. And most miter saws don't have the depth capability to make the 12" cut (only the 12" sliding saws can do it.)
There's no reason to not use the table saw IF you pay attention and use proper safety measures.
Personally, I wouldn't try to cut 6" pieces off the end of an 8' strip of plywood...use the circular saw to cut it into more manageable pieces first (say 2' long), then slice off the smaller pieces.
dejure in reply to alanemartinJan 22, 2013. 9:53 AM
Based on my experience, as forty year cabinet saw owner and someone in the wood trades, I say:
All saws come with splitters, but get tossed because they take too long to remove and install. The have to be removed to make rabbit and dado cuts, or any cut in which the blade does not go through the wood.
Newer saws come with Riving knives that do what a splitter does, but go up and down with the blade, so don't have to be removed.
Like a large percentage of tradesmen, I ran without a splitter on my commercial saws because of the problem with installation and removal. I spent a not insignificant amount on a splitter (Merlin) which installs and removes in seconds and my kick back problem all but went away (it can still happen).
All that said, the advice to not use the rip fence to cut boards to shorter lengths (cross cuts) is sound - use the miter push. Add to that that to NEVER USE THE MITER AT THE SAME TIME YOU USE THE RIP FENCE FOR ANY PROJECT. The only exception is if you have a Unifence and back the end of the fence off for use as a stop gauge, with it positioned so the wood clears it before entering the blade.
kick, the advice above is critical. Rip fences are for ripping long cuts and miter pushes are for cutting
smokehill in reply to timlawyerMar 3, 2008. 8:50 PM
This can happen with radial arm saws, too, as I found out the hard way.
On radials, the piece usually shoots out the back, rather than the front, of the saw. While paying not nearly enough attention, I shot a small piece of plywood about twenty feet, almost hitting my partner's head. It made a quite visible dent in the new drywall, and scared the **** out of both of us.
Power saws are downright dangerous, and you have to pay attention.
Eye Poker in reply to smokehillNov 14, 2009. 1:12 PM
My first and only kickback mistake with a table saw sent a six inch piece of particle board flying like a ninja star about 150 yards.  Luckily, I was outside and no one was in the way.
mysterygirl154 in reply to smokehillJul 9, 2009. 12:57 PM
In our shop class there is a huge dent in the blackboard on the other side of the room from when someone did that. It's incredibly lucky that it didn't hit anyone.
innerbubba (author) in reply to timlawyerOct 8, 2007. 11:18 PM
Tim is right. I live dangerously, but my life is worthless. You should be careful.
_soapy_ in reply to timlawyerNov 1, 2006. 4:34 AM
Better yet, use a handsaw and wear boxing gloves.
moniquebraga says: Oct 5, 2012. 10:45 AM
So cool!
breumer says: Jul 22, 2012. 4:51 AM
Great instructable ! Thanks !
frannyloo says: Mar 29, 2009. 2:01 PM
this is a fantastic instructable! but i don't have the things needed to cut plywood, nor do i have the plywood. do you think this might work with with something else?? like cardboard maybe..?
Dianasis in reply to frannylooJul 1, 2012. 3:07 PM
If you buy the plywood through Lowes, Home Depot or most local hardware stores, they'll cut the wood for you.....unless you show up during the busiest times of the week like noon on Saturday.
eldavoloco in reply to frannylooOct 19, 2009. 11:08 AM
  I just checked out lumber...you can by 1in. x 6in. x 8ft. length. 2 pieces would be enough to make this project. You could make wider shelves by using 1in. x 10 in. x 8 ft. boards (again, 2).
Buying this size lumber means you would only have to make 6 inch or 10 inch cuts across the boards to get your 1 foot pieces.
Dudeyowuzup in reply to eldavolocoFeb 17, 2012. 8:33 AM
Thanks for the suggestion & the price quote (in your post below).
For those who don't have a saw, Lowes & Home Depot each have a cutting station where you can bring the board you are buying and they will cut it for you. I've been to different locations. One said the first cut per board was free, 50cents each cut after that. Another said all cutting was free (with the purchase of their lumber I'm sure.) Either way, it's totally worth an extra 50cents each cut for them to cut it on their nice big efficient apparatus, considering I live in a little 2-bedroom apartment with no yard (at least I have a patio!), no cutting table or saw horses, and the only power saw I have is a jig saw (can you imagine how long it would take me to make all those cuts??)
spydog4 in reply to frannylooJun 16, 2009. 8:33 AM
search "cardboard lumber" there's a great instructable on how to make "wood" out of cardboard
David_n_Redena says: Jan 28, 2012. 4:48 PM
Your bookcase design was great. I used 2 of them to fill in a doorway that was not needed anymore. I backed it with sheetrock painted the wall color.
innerbubba (author) in reply to David_n_RedenaMay 10, 2012. 4:45 PM
Wow! That looks great!
David_n_Redena in reply to innerbubbaMay 10, 2012. 5:36 PM
thanks!!
cardboardguy says: May 10, 2012. 1:30 PM
Nice and simple idea. I did my own variation on this design. They are stackable modules that can be rearranged at will.
felipe yoqesemas says: May 3, 2012. 7:04 AM
in spanish please. No hay solo ingleses interesados en estos proyectitos. Yo no me interesaria si no fuera obligatorio para aprobar tecnologia. LOS ESPAÑOLES SOMOS UNOS MANITAS. Y yo no tengo 35 años... se me fue el 3
Semper Fi says: Apr 15, 2012. 7:57 PM
Thanks for the great idea. Made these with my son in law.
cuevassweetie says: Dec 19, 2011. 3:35 PM
Love your design! I'm wondering what you might think of the structural integrity of this bookshelf if I was to put a mattress on top and 3-4 of these guys lined up. Im in desperate need of more bookselfs and under the bed is my only option now :o)
heartlesskitten88 says: Nov 28, 2011. 10:39 AM
I'm giving these instructions to my husband so he can build his own bookcase and get all those giant auto manuals off my bookcase!! Thanks for sharing bubba :)
den126 says: Oct 28, 2011. 4:06 AM
My "vertical" version
innerbubba (author) in reply to den126Nov 4, 2011. 4:11 PM
Nice job! Yours came out looking great!
callmechaos in reply to den126Nov 4, 2011. 8:48 AM
Cool bookshelf! We love it!
I plan to make one and paint the back board one
color and the other areas another bold color for a "funky- look". (I am so inspired that I may even start on it before I finish the other 50 projects that I am working on!! ha!)
Speaking of that "extra money" you don't have anymore-- you could always moonlight as a comedian! Reading your instructions, etc you have us cracking up over here!!
tradmer says: Mar 11, 2011. 10:42 AM
Built 2 of these this weekend - one for books, one for DVD's... found out too late that the large board my pieces were cut from was bowed. (Damnit Home Depot!) So.. unless you like that curved "it's a puzzle!" look.. make sure your board is straight. =/
gollihughj says: Jan 29, 2011. 9:16 AM
innerbubba... your life is not worthless... just in this Instructable you have given me hope that I might outfit my "library" wtih shelves that I REALLY need (to get my books out of boxes), in a way that will be attractive and super helpful to me and my family. I'm sure you so many other useful and even valuable things... like attracts like. Be more positive and you will attract more of that to your life! And so it goes and you'll feel and, even, BE an even better person than you already are in little to no time. :)
CraigStanton says: Jan 2, 2011. 7:03 PM
Thanks for the inspiration, nicely used up a plank I've had sitting around for a while. I might even go buy more so I can make it reach the ceiling now.
DesignerUserName says: Nov 15, 2010. 11:02 AM
Saw this ages ago, then moved into a room with NO CLOSET and suddenly remembered seeing it. I constructed mine taller and deeper to hold shoes :) (Hey, I'm a woman!)
SkizMaroo says: Nov 11, 2010. 4:24 PM
Lol, cool brainfart. PBR never affects my creativity quite like that :-)
dptlord says: Jul 14, 2010. 11:06 AM
Not really a $10 project either, but for $35, I can make two for less than the price of one 4' floating shelf! It looks great, and is still affordable (and easy enough for those like me who aren't so skilled in construction)!
fiducianullus says: May 14, 2010. 6:47 PM
 Mine came out GREAT. 2" drywall screws and bam... stable.
ravijojla says: Jan 28, 2010. 7:47 AM
This is a bit more then '60 seconds' but definetly worth a try... Thanks!
fiducianullus in reply to ravijojlaMay 14, 2010. 6:46 PM
 It says "60 minute"
tiptop44890 says: Apr 27, 2010. 8:11 AM
Looks to be easy to build gonna build a few of them and add some things to it myself
jollymoon says: Mar 26, 2010. 11:11 AM
How do you make the bookshelf more stable so it doesn't fall over?  It looks kinda narrow and with 40-50 paperbacks on it what keeps it from tipping forward or sideways??
rrod436 says: Feb 16, 2010. 6:18 AM
Love this. I've made two so far. Used my own dimensions and added some copper rods to the open ends of one ( dvd rack ).
mo37 says: Feb 15, 2010. 11:45 PM
very nice...
1-40 of 137Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
