Warning: this procedure involves extensive lame woodworking techniques such as glueing and stapling with nailguns. If you're a dovetail joint purist, you probably don't want to read any further.
Remove these ads by
Signing UpStep 1Ingredients
- a table saw
- a nail gun
Material you will need:
- at least a quarter of a plywood sheet, 96" long x 12" wide x 3/4" thick.
- at least 60 1.25" brads for the nail gun
- wood glue
- sand paper
- pabst blue ribbon, to help you channel your inner bubba.
Note: User earay indicates that MDF might be a better substitute for plywood, as it is cheaper and easier to paint when complete.
Buying this size lumber means you would only have to make 6 inch or 10 inch cuts across the boards to get your 1 foot pieces.
For those who don't have a saw, Lowes & Home Depot each have a cutting station where you can bring the board you are buying and they will cut it for you. I've been to different locations. One said the first cut per board was free, 50cents each cut after that. Another said all cutting was free (with the purchase of their lumber I'm sure.) Either way, it's totally worth an extra 50cents each cut for them to cut it on their nice big efficient apparatus, considering I live in a little 2-bedroom apartment with no yard (at least I have a patio!), no cutting table or saw horses, and the only power saw I have is a jig saw (can you imagine how long it would take me to make all those cuts??)
I plan to make one and paint the back board one
color and the other areas another bold color for a "funky- look". (I am so inspired that I may even start on it before I finish the other 50 projects that I am working on!! ha!)
Speaking of that "extra money" you don't have anymore-- you could always moonlight as a comedian! Reading your instructions, etc you have us cracking up over here!!
There's no reason to not use the table saw IF you pay attention and use proper safety measures.
Personally, I wouldn't try to cut 6" pieces off the end of an 8' strip of plywood...use the circular saw to cut it into more manageable pieces first (say 2' long), then slice off the smaller pieces.
On radials, the piece usually shoots out the back, rather than the front, of the saw. While paying not nearly enough attention, I shot a small piece of plywood about twenty feet, almost hitting my partner's head. It made a quite visible dent in the new drywall, and scared the **** out of both of us.
Power saws are downright dangerous, and you have to pay attention.
This is a bit more then '60 seconds' but definetly worth a try... Thanks!
This worked fantastic and was super easy! I made mine one level shorter because it seemed a little unstable to put on carpet, with stuff on it. You could also add some little legs to increase stability. But overall this was a fantastic idea for an instructable. I wouldn't mind trying it in cardboard, too. Great job!
