3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
60-minute bookcase
60-minute bookcase
I had a brainfart this morning that transformed a $10 spare scrap of plywood into a really cool 5' tall, designery bookcase that some yuppie idiot would probably pay a few hundred for.
Warning: this procedure involves extensive lame woodworking techniques such as glueing and stapling with nailguns. If you're a dovetail joint purist, you probably don't want to read any further.
Step 1Ingredients
Ingredients
Tools you will need:
- a table saw
- a nail gun
Material you will need:
- at least a quarter of a plywood sheet, 96" long x 12" wide x 3/4" thick.
- at least 60 1.25" brads for the nail gun
- wood glue
- sand paper
- pabst blue ribbon, to help you channel your inner bubba.
Note: User earay indicates that MDF might be a better substitute for plywood, as it is cheaper and easier to paint when complete.
132 comments
1-40 of 132next »
Jan 28, 2012. 4:48 PMDavid_n_Redena says:
Your bookcase design was great. I used 2 of them to fill in a doorway that was not needed anymore. I backed it with sheetrock painted the wall color.
May 10, 2012. 5:36 PMDavid_n_Redena says:
thanks!!
May 10, 2012. 1:30 PMcardboardguy says:
Nice and simple idea. I did my own variation on this design. They are stackable modules that can be rearranged at will.
May 3, 2012. 7:04 AMfelipe yoqesemas says:
in spanish please. No hay solo ingleses interesados en estos proyectitos. Yo no me interesaria si no fuera obligatorio para aprobar tecnologia. LOS ESPAÑOLES SOMOS UNOS MANITAS. Y yo no tengo 35 años... se me fue el 3
Apr 15, 2012. 7:57 PMSemper Fi says:
Thanks for the great idea. Made these with my son in law.
Mar 29, 2009. 2:01 PMfrannyloo says:
this is a fantastic instructable! but i don't have the things needed to cut plywood, nor do i have the plywood. do you think this might work with with something else?? like cardboard maybe..?
Oct 19, 2009. 11:08 AMeldavoloco says:
  I just checked out lumber...you can by 1in. x 6in. x 8ft. length. 2 pieces would be enough to make this project. You could make wider shelves by using 1in. x 10 in. x 8 ft. boards (again, 2).
Buying this size lumber means you would only have to make 6 inch or 10 inch cuts across the boards to get your 1 foot pieces.
Feb 17, 2012. 8:33 AMDudeyowuzup says:
Thanks for the suggestion & the price quote (in your post below).
For those who don't have a saw, Lowes & Home Depot each have a cutting station where you can bring the board you are buying and they will cut it for you. I've been to different locations. One said the first cut per board was free, 50cents each cut after that. Another said all cutting was free (with the purchase of their lumber I'm sure.) Either way, it's totally worth an extra 50cents each cut for them to cut it on their nice big efficient apparatus, considering I live in a little 2-bedroom apartment with no yard (at least I have a patio!), no cutting table or saw horses, and the only power saw I have is a jig saw (can you imagine how long it would take me to make all those cuts??)
Jun 16, 2009. 8:33 AMspydog4 says:
search "cardboard lumber" there's a great instructable on how to make "wood" out of cardboard
Dec 19, 2011. 3:35 PMcuevassweetie says:
Love your design! I'm wondering what you might think of the structural integrity of this bookshelf if I was to put a mattress on top and 3-4 of these guys lined up. Im in desperate need of more bookselfs and under the bed is my only option now :o)
Nov 28, 2011. 10:39 AMheartlesskitten88 says:
I'm giving these instructions to my husband so he can build his own bookcase and get all those giant auto manuals off my bookcase!! Thanks for sharing bubba :)
Oct 28, 2011. 4:06 AMden126 says:
My "vertical" version
Nov 4, 2011. 8:48 AMcallmechaos says:
Cool bookshelf! We love it!
I plan to make one and paint the back board one
color and the other areas another bold color for a "funky- look". (I am so inspired that I may even start on it before I finish the other 50 projects that I am working on!! ha!)
Speaking of that "extra money" you don't have anymore-- you could always moonlight as a comedian! Reading your instructions, etc you have us cracking up over here!!
Feb 8, 2006. 11:26 AMtimlawyer says:
WARNING - DO NOT USE THE RIP FENCE to make the series of 6inch cuts shown here. Use a miter or cross cut saw guide. The way it is described here, you are essentially cutting off 6inch ends from a long rectangle that is perpendicular to the saw blade. DO NOT USE THE RIP FENCE because if the cut off piece pinches between the rip fence and the very back of your saw blade - THE 6inch CUT OFF WILL FLY BACK AT YOU AT OVER 100MPH - ENOUGH TO KILL YOU.
Oct 6, 2011. 1:44 PMalanemartin says:
A properly equipped table saw should have a splitter behind the blade to help prevent this very issue. And most miter saws don't have the depth capability to make the 12" cut (only the 12" sliding saws can do it.)
There's no reason to not use the table saw IF you pay attention and use proper safety measures.
Personally, I wouldn't try to cut 6" pieces off the end of an 8' strip of plywood...use the circular saw to cut it into more manageable pieces first (say 2' long), then slice off the smaller pieces.
Mar 3, 2008. 8:50 PMsmokehill says:
This can happen with radial arm saws, too, as I found out the hard way.
On radials, the piece usually shoots out the back, rather than the front, of the saw. While paying not nearly enough attention, I shot a small piece of plywood about twenty feet, almost hitting my partner's head. It made a quite visible dent in the new drywall, and scared the **** out of both of us.
Power saws are downright dangerous, and you have to pay attention.
Nov 14, 2009. 1:12 PMEye Poker says:
My first and only kickback mistake with a table saw sent a six inch piece of particle board flying like a ninja star about 150 yards.  Luckily, I was outside and no one was in the way.
Jul 9, 2009. 12:57 PMmysterygirl154 says:
In our shop class there is a huge dent in the blackboard on the other side of the room from when someone did that. It's incredibly lucky that it didn't hit anyone.
Nov 1, 2006. 4:34 AM_soapy_ says:
Better yet, use a handsaw and wear boxing gloves.
Mar 11, 2011. 10:42 AMtradmer says:
Built 2 of these this weekend - one for books, one for DVD's... found out too late that the large board my pieces were cut from was bowed. (Damnit Home Depot!) So.. unless you like that curved "it's a puzzle!" look.. make sure your board is straight. =/
Jan 29, 2011. 9:16 AMgollihughj says:
innerbubba... your life is not worthless... just in this Instructable you have given me hope that I might outfit my "library" wtih shelves that I REALLY need (to get my books out of boxes), in a way that will be attractive and super helpful to me and my family. I'm sure you so many other useful and even valuable things... like attracts like. Be more positive and you will attract more of that to your life! And so it goes and you'll feel and, even, BE an even better person than you already are in little to no time. :)
Jan 2, 2011. 7:03 PMCraigStanton says:
Thanks for the inspiration, nicely used up a plank I've had sitting around for a while. I might even go buy more so I can make it reach the ceiling now.
Nov 15, 2010. 11:02 AMDesignerUserName says:
Saw this ages ago, then moved into a room with NO CLOSET and suddenly remembered seeing it. I constructed mine taller and deeper to hold shoes :) (Hey, I'm a woman!)
Nov 11, 2010. 4:24 PMSkizMaroo says:
Lol, cool brainfart. PBR never affects my creativity quite like that :-)
Jul 14, 2010. 11:06 AMdptlord says:
Not really a $10 project either, but for $35, I can make two for less than the price of one 4' floating shelf! It looks great, and is still affordable (and easy enough for those like me who aren't so skilled in construction)!
May 14, 2010. 6:47 PMfiducianullus says:
 Mine came out GREAT. 2" drywall screws and bam... stable.
Jan 28, 2010. 7:47 AMravijojla says:
This is a bit more then '60 seconds' but definetly worth a try... Thanks!
May 14, 2010. 6:46 PMfiducianullus says:
 It says "60 minute"
Apr 27, 2010. 8:11 AMtiptop44890 says:
Looks to be easy to build gonna build a few of them and add some things to it myself
Mar 26, 2010. 11:11 AMjollymoon says:
How do you make the bookshelf more stable so it doesn't fall over?  It looks kinda narrow and with 40-50 paperbacks on it what keeps it from tipping forward or sideways??
Feb 16, 2010. 6:18 AMrrod436 says:
Love this. I've made two so far. Used my own dimensions and added some copper rods to the open ends of one ( dvd rack ).
Feb 15, 2010. 11:45 PMmo37 says:
very nice...
Jan 30, 2010. 9:24 PMmrguy19187 says:
This worked fantastic and was super easy! I made mine one level shorter because it seemed a little unstable to put on carpet, with stuff on it. You could also add some little legs to increase stability. But overall this was a fantastic idea for an instructable. I wouldn't mind trying it in cardboard, too. Great job!
Jan 27, 2008. 8:15 PMGorillazMiko says:
Awesome... gotta show this to my dad, I wan't one. I'm going to paint it black if I do it. Neat job. (added to favorites)
Woops, I meant "want", not "wan't". :P
Jul 5, 2009. 8:26 PMYerboogieman says:
No you didn't.
Jan 29, 2010. 7:40 AM--scare-- says:
LOLERZ!!
1-40 of 132next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:innerbubba
I used to be a yuppie, but buying a house cured me of my excess money problem. Now I attempt to replicate the designer furniture of my dreams by channeling my inner bubba through a set of borrowed po...
more »
