Remove these ads by
Signing UpStep 1Main Frame Construction
- 35mm box section steel or similar (roughly 3 meters of the stuff)
- old BMX headtube
Tools
- steel rule
- tape measure
- scribe
- hacksaw or electric auto one!
- engineer's square
- 200 amp MIG welder
- hand file (rounded and flat)
- electric grinder (speeds up filing and cleans up welds)
- various clamps and vices
1. Cut the box section steel to lengths of 1000mm (1 metre) for each piece
2. Front piece of steel is shape around radius of BMX headtube at a 10 degree angle of rake
3. Cut off headtube from BMX and file or grinder
4. File small 45 degree chamfers and the ends of the box section steel around the edges for better welds
5. Weld all these parts together as pictured
6. Grind on top of frame at the "t" join for a nice finish
7. BEFORE YOU WELD MAKE METAL SHINY BY FILING SO YOU HAVE A GOOD SURFACE
p.s you don't to follow the exact dimension, just my design has those
Sam
Cheers
I actually got them from the same place as the batteries- a local hardware farm store. They had a selection and once I saw them they looked perfect!
You can also get them here: www.technobots.co.uk/cgi-bin/ss000002.pl
Hope that helps!
The front is from a kids bike- alloy rim etc etc
The batteries are (about £40 each) :
Numax 'Ev Power', Deep Cycling Battery, 32ah, TYPE 896cxt
You could probably find an alternative to this as there are plenty of other manufacturers.
Here is a great site to also look at for information on building electric vehicles:
http://buggies.builtforfun.co.uk
Cheers
Sam
Ebay 350W 24V Scooter Motor
Also, I second noah's question- is this a GCSE/A-level tech project? And kudos for actually going into detail about the shop work part, not just "throw the sprockets in your lathe and turn them down so they fit the wheels" :)
