This instructable has been removed by the author.
27
comments
Add Comment
http://www.lowes.com/pd_112447-427-915C_4294821893_4294937087_?productId=3127553&Ns=p_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1&pl=1¤tURL=%2Fpl_Electrical%2BBox%2BCovers_4294821893_4294937087_%3Fpage%3D6%26Ns%3Dp_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1&facetInfo=
for the cover,
http://www.lowes.com/pd_70965-427-8232_4294821892_4294937087_?productId=3129407&Ns=p_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1&pl=1¤tURL=%2Fpl_Electrical%2BBox_4294821892_4294937087_%3FNs%3Dp_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1&facetInfo=
for the box,
and this type set up:
http://www.lowes.com/pd_172498-46-4317824_0__?productId=3235312&Ntt=appliance+cord&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dappliance%2Bcord&facetInfo=
to supply the power.
While cutting up a plastic cover is probably going to work out just fine for the outlet/timer, hacking up the multiplug and then gluing/soldering it in place is a bad idea. Considering that the point of this is to protect the user from accidents involving potentially dangerous, high amperage equipment, you should not rely on improvised soldering on a damaged piece of equipment to safely supply the power. This is asking for some serious trouble.
Again, I don't mean to bash at all. You are correct that basic electrical wiring is not "rocket science" but it is something that has to be done right. My customers always say that electrical work is the one thing they are afraid of doing themselves. My response is always that electricity is not something to fear but it is something you must respect. The bottom line is that the consequences of something going wrong with this stuff can be real bad real fast. Please be safe.
Best Regards (73 in HAM lingo)
I am not trying to be nasty in any way but I can see that this could be dangerous in many ways in the hands of inexperianced people.
The thing I tell people that do thier own electrical work is
Are you willing to risk the life of your family members & children if you make a mistake.
Cbaabc73 - please don't let us discourage you from making more Instructables. The concept, presentation and final appearance are all great.
I look forward to seeing what else you bring to this community!
I visited that store site and... not recommend it at all
Even that timer... uf! so expensive 16$!!!! Read comments of customers, talking about bad construction in addition.
I think I can buy one here in Spain and send you (paying sending expenses) and it is cheaper for you!!!
Another option is a digital one with a plug on it, which you can program for the whole week (if your wife has same time to do house things (for about <6$)
Why not using ?
I would ike to buy one but i cant find a mechanical one like the one you posted on the left! Where did you find the picture? I would like to know which shop it is!
and edited in Photoshop.
I bought several in Brico-depôt (belongs to Kingfisher group, I do not know if you have any one close to you)
And the price was less than 4€ (It was an offer, usually about 7€)
And, watching their site..., e-commerce-less, sorry
http://www.intermatic.com/Products/TimeSwitches/Electromechanical_Switches/SpecialtySwitches/Mechanical_Water_Heaters.aspx
The only way to activate the two plugs is to select a time (10, 20, 30, 60 min) but the switch controls the bottom outlet, allowing individual appliances to be turned on and off. I use the switch to plug in my soldering iron.
This partly came around because i was asked to keep from burning the house down because I would regularly keep soldering iron running. However the timer is also handy for saving electricity on lighting and vampire power to all the garage appliances.
You can buy the socket for that type of cord from surplus supply outlets such as Mouser Electronics: Mouser Part #: 562-716W-X2/02
Manufacturer Part #: 716W-X2/02
Manufacturer: Qualtek
Description: Power Entry Modules SNAP-IN MNT SLDR
This could be easily attached to the "box" you are using. This would eliminate the cutting and gluing of the male plug.
However, gone are the days when we can recharge an electric toothbrush in the bathroom, or plug in a space heater in the winter to keep it warm in there... I made BOTH outlets controlled to the timer! Maybe not such a good idea, but it does make it simpler for her to remember :)
-e
I personally would rather build this to be IN the wall, using a combo wall plate to finish it. Wiht this, I can see a) the wife gets tired of using the timer and pulls the unit out of the wall or b) the weight of the cord and box pulls it out of the wall.
I like your design. It looks like you are plugging this into a wall outlet. To make something easier couldn't you expand your outlet in the wall by 2 and add the timer beside it? Did you consider going this route?
I wonder if there is a better part to buy to use for the metal male plugs on the back. I would only want one plug and to attach an extension cord to it.
Thanks.
I also wanted to control an outlet with a rheostat (dimmer) for a cheap, temperature controlled soldering iron hack.
