3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
660nm LED face mask
660nm LED face mask
My family have skin problems and after using a proprietary LED unit to treat cold sores, not only did it clear them up quickly than medicinal creams, I have not had another since. I decided after this sucess that I might be able to help by making a full face mask with a number of LEDs
It uses what is called Red Light Therapy which is the application of a narrow spectral width in the red or near infra-red spectrum  to promote cell regeneration and reduce inflammation. It is believed that the displacement of NOMT (Mitochondrial Nitric Oxide) in cells leads to an improved healing performance
Use for 1 minute at least 3 times a day but not more that once in one hour (this could reduce effectiveness of the treatment). Do not use in conjunction with any creams including anti-viral applications for Herpes Simplex outbreaks (cold sores)
WARNING do not look directly at the light emitted from the leds, they are NOT lasers but are very bright
Step 1Attaching and wiring up
Using a proprietary LED constant current driver designed for domestic led lighting was the actually the cheapest and simplest way to provide power. I obtained 5 x 1watt LEDs at 660nm which is the defined efficacious wavelength. These were in total with the the PSU USD20. I glued the leds into a face mask bought out of the childrens craft section at the local supermarket and connected the leds in series, + to - and so on. I connected the supply to the 2 outer leds making sure to keep correct polarity
10 comments
Aug 17, 2011. 5:21 PMrivetgeek says:
I'm pretty sure led light doesn't affect the herpes virus, but good build I guess.
Aug 29, 2011. 2:20 PMrivetgeek says:
infrared or ultraviolet frequencies i MIGHT believe. Visible light does not carry enough energy.
Aug 27, 2011. 5:42 PMTaresa says:
Google LED light therapy, light therapy for acne and wrinkles, etc etc. LED light therapy is used in dermatologists offices to kill acne bacteria (blue) and improve collagen (red). There are also light therapy kits you can buy to place on sore muscles.
I was looking to buy a set on Amazon for $350 but am hoping this instructable will save me the money.
Aug 29, 2011. 1:22 PMTaresa says:
Exactly - the devices sold by Tanda, and other brands on Amazon, incorporate red and blue commonly.
Here's an article I've learned a lot from:
http://www.dermadoctor.com/article-print.asp?ArticleID=396
My sister in law actually went to her dermatologist for the LED light therapy treatments and had beautiful results. As explained on the product pages, it takes several treatments at first. Maintenance is less frequent.
I'm not sure which LED's or what power supply to use though. That's why we came to check out this instructable!
Some reviewers on Amazon have noted some sensitivity to the light, so I was wondering if we could build in a way to dim the light. Also some said a built in timer was helpful in many models. The bigger devices sit on a surface and require you to lean into them... pretty uncomfortable for 15 minutes even. My husband and I have been brainstorming... we're thinking to get a welding face shield and drill holes in it to poke the LED's into. They also all recommend using tanning goggles to protect your eyes.
I have a dull concern that the lights will also kill off beneficial bacteria. There doesn't seem to be research or any statement on that, though. Maybe it's not as important on your facial skin?
Thanks for your reply!
Aug 30, 2011. 2:22 PMrivetgeek says:
Your article is for treatment of acne, not herpes. One is a virus, and one is bacteria.
Aug 30, 2011. 3:08 PMTaresa says:
Of course, I'm trying to come up with a mod for this instructable to use LED's to treat acne and wrinkles.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Avicenna(Peter Bradley)
