6v Regulator
8,819
35
5
Posted in TechnologyElectronics
Introduction: 6v Regulator
This is a circuit used to convert a voltage range of 7.5-16v to 6v 1A output this circuit consist of 7806 regulator IC and few capacitors the circuit is simple and easy to make and can be used as a bread board powersupply and for charging 6v batteries and lots of other purposes
Step 1: Parts
1         1 x 7806 IC
2         2 x 470 uf (electrolytic capacitor)
3         1 x small piece of common circuit board
Step 2: Circuit Diagram
make the ciruit according to the circuit diagram provided and use an aluminium plate as a heatsink to the IC or else the IC will get overheated and damaged
Step 3: Conclusion
use this circuit according to the purpose you need and dont forget to add the heatsink.. to IC
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    5 Comments
    The IC becomes too hot without heatsink. and IC may get damaged due to overheating of IC
    discharge of output capacitor when switch off, couse regulator fal, see datasheet.
    Add a protection diode?
