3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
7 Foot Axial Flux Wind Turbine
Step 10Generator Testing
Generator Testing
To gather data on the output of the generator, you'll need a few things. Mainly a couple of good multimeters, a test load, and some way to read the RPM.
I attempted to use the equipment in my physics lab and Datastudio to measure the frequency of the AC current, then I tried to work backwards to figure out the RPM of the generator. If I remember correctly, I had to divide by 6 to get the RPMs. This method, however... was extremely inaccurate. I kept getting readings that were very off. Despite the pretty graphs the equipment was generating, I would not recommend trying to use this method for measuring RPM.
Many people use fancy bicycle tachometers with good results. Some bicycle tachometers can be found for under $20. Luckily my physics teacher is an avid bicycle rider and had a box full of old bicycle computers that he let me try out. I found one with an RPM counter and zip tied a neodymium magnet onto one side of the testing jig. Then I used a ring stand and a clamp to hold the sensor in place. Now I could read the RPMs fairly easily, although they didn't update immediately this method was far more accurate. I would highly suggest if you want accurate readings to get a decent tachometer or a bicycle computer with an RPM setting.
I was also able to use Datastudio to measure the DC voltage coming off the generator. The equipment only measured up to 10 volts DC, so I used a simple voltage divider to scale down the voltage being read by the computer. This allowed the computer to read 1/12 the voltage being produced. So the actual voltage on the graph was 12 times voltage read by the computer. See pictures for the schematic. The voltage across R2 should be 1/12 the voltage of the generator, this is shown in the graph.
Also, I needed to flatten out the DC coming off the rectifier. To do this I used a big capacitor in parallel to flatten out the voltage spikes, giving a more accurate DC voltage reading. You have to watch a lot of things when you spin up the generator. It's hardest to measure voltage, current and rpm while still holding onto the drill.
For my test load, I used six 18 ohm 25 watt resistors in parallel for a total of 3.6 ohms.
1 comment
Dec 27, 2009. 10:52 PMmahesh.ganpate says:
va....v very nice please send deatails images and drawing for genereter rating details i m starting a new wind turbine 1 kw manufacturing by home made . then so pls help
Dec 31, 2009. 3:30 AMmahesh.ganpate says:
thanks , for u r sugess but we wont to 1kw genereter making the basicaliy rating of genereter  and  iwas perchasing this wec book but there not specifiy ingenereter rating ditails and wave deatials . i thk u r sugess me  .genereter details . india  here ueing the matric system . but book in site all dimanstion mph inch etc there  .
Jan 2, 2010. 5:41 AMmahesh.ganpate says:
tx brokengun,
  i have agree with u u r coment  i have making  for axial flux genereter. but i don't know  which parameter using for generotor making,   only 30 mtr tower bearing ,gue rope , tail van avalable  here  but  genertor details not avalable
Jan 4, 2010. 6:58 AMmahesh.ganpate says:
how much price sir , book parchasing ,im not parchasised book
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:brokengun
