Step 9Testing Jig
Now, a lot of people have a lathe, a tachometer and a bunch of other fancy tools to test their generators. Well, I am a bit less fortunate and do not have those available to me. So, instead, I made a simple jig to spin up my generator using an electric drill.
I cut a notch in a small piece of wood and shaped it as a trapezoid to avoid all the holes for the bolts. On the other side, I screwed through a hole in the metal into the wood to hold it in place. The other two planned attachment places were too close to the edge to take a screw, so I drilled a couple of small holes and used small zip-ties. Surprisingly, this setup is pretty solid. The piece of wood doesn't act like it's going anywhere and those zip-ties are nice and snug.
Now, with all of these funny angles and stuff, it's hard to find the exact center of the rotor. I did the best I could to eyeball it and I drilled two more long screws partway into the wood on either side of the center. Then use an allen wrench with a T-handle on it that is long enough to touch these two screws. These screws will take the torque from the drill to spin up the generator.
comment
Add Comment
Add Comment
