7 Segment Display on Arduino
170,519
60
32
Published
Introduction: 7 Segment Display on Arduino
This instructable shows how to display 0-9 digits on 7 Segment Display using Arduino.
What do you need:
  • Arduino Uno 3
  • 7 Seven Segment Display
  • 2 x 220 Ohm Resistors
  • Jumper Wires
Step 1: Making Connections
Connect the pins described below:
  1. Arduino Pin 2 to Pin 9.
  2. Arduino Pin 3 to Pin 10.
  3. Arduino Pin 4 to Pin 4.
  4. Arduino Pin 5 to Pin 2..
  5. Arduino Pin 6 to Pin 1.
  6. Arduino Pin 8 to Pin 7.
  7. Arduino Pin 9 to Pin 6.
  8. GND to Pin 3 and Pin 8 each connected with 220 ohm resistors.
Step 2: Arduino Code
int a = 2;  //For displaying segment "a"
int b = 3;  //For displaying segment "b"
int c = 4;  //For displaying segment "c"
int d = 5;  //For displaying segment "d"
int e = 6;  //For displaying segment "e"
int f = 8;  //For displaying segment "f"
int g = 9;  //For displaying segment "g"
void setup() {
  pinMode(a, OUTPUT);  //A
  pinMode(b, OUTPUT);  //B
  pinMode(c, OUTPUT);  //C
  pinMode(d, OUTPUT);  //D
  pinMode(e, OUTPUT);  //E
  pinMode(f, OUTPUT);  //F
  pinMode(g, OUTPUT);  //G
void displayDigit(int digit)
 //Conditions for displaying segment a
 if(digit!=1 && digit != 4)
 digitalWrite(a,HIGH);
 //Conditions for displaying segment b
 if(digit != 5 && digit != 6)
 digitalWrite(b,HIGH);
 //Conditions for displaying segment c
 if(digit !=2)
 digitalWrite(c,HIGH);
 //Conditions for displaying segment d
 if(digit != 1 && digit !=4 && digit !=7)
 digitalWrite(d,HIGH);
 //Conditions for displaying segment e
 if(digit == 2 || digit ==6 || digit == 8 || digit==0)
 digitalWrite(e,HIGH);
 //Conditions for displaying segment f
 if(digit != 1 && digit !=2 && digit!=3 && digit !=7)
 digitalWrite(f,HIGH);
 if (digit!=0 && digit!=1 && digit !=7)
 digitalWrite(g,HIGH);
void turnOff()
  digitalWrite(a,LOW);
  digitalWrite(b,LOW);
  digitalWrite(c,LOW);
  digitalWrite(d,LOW);
  digitalWrite(e,LOW);
  digitalWrite(f,LOW);
  digitalWrite(g,LOW);
void loop() {
 for(int i=0;i<10;i++)
   displayDigit(i);
   delay(1000);
   turnOff();
14 People Made This Project!
  • Planter Challenge
    Planter Challenge
  • Clocks Contest
    Clocks Contest
  • Oil Contest
    Oil Contest
32 Comments
its working great, better to configure the jumper wires as its in the fritzing diagram.
Thanks
This is an example only for "Common katode" , am i right?
to save the arduino pins from overload
! is like saying not.
!= means 'not equal'
Doesn't work correctly. could you tell me why.
Confirm if you have exact same components? Have you made right connections? Copied all code?
me 2 bro.. not work correctly.. fix this if u can.
Hey! Try to switch from GND to VCC. It worked for me. If you search for a datasheet or a pinout description you will notice that the 3 and 8 pins are connected to VCC not GND. Try this way...maybe it will work.
5 star bro ! your the man!
haha its works!! i owe you much for our project!
thanks a lot!
Connections which is in the circuit diagram is the correct one.
Connections which is in the description is wrong
Correct description
  1. Arduino Pin 2 to Pin 7.
  2. Arduino Pin 3 to Pin 6.
  6. Arduino Pin 8 to Pin 9.
  7. Arduino Pin 9 to Pin 10.
thanks very much (y) ...at last it worked ....
maby you have a wrong 7 segment display maby it's a common cathode
Correct description
HERE IS THE FIX!!!!!!!!!!!!!!!!!!! the code is defunct now due to newer IDE versions: to fix the code change in the line of Void Loop
remove int after for(i=0;i<10;i++) < should look like this
and in the same Void loop add this line before the if statement
int 1;
so it should look like :
void loop()
int i;
for( i = 0; i< 10; i++);
DONE
Where is the code for this?
Worked fine
Thank-you for sharing
The reason it does'nt work is because Arduino pin 1 and 7 is not used, correct code :
digitalWrite(2,LOW);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
digitalWrite(5,LOW);
digitalWrite(6,LOW);
digitalWrite(8,LOW);
digitalWrite(9,LOW);
And yes, I made it but don't have an image :D
