3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
700-Lumen LED Bike Light
Equivalent light output of a 70-watt halogen bulb but only uses12-watts of power.
Beam shots show a building at night 100-ft away illuminated by this LED bike light.
Detailed Specs and Parts List are given at the end of Step 8.
Step 1Building the Enclosure
Step 1: Enclosure
A. These are the parts needed for the enclosure and shown before cutting to size: Lexan MR10 plastic, 1/16-inch x 3/4-inch aluminum L-bracket, Hammond enclosure, heat sink.
B. Cut parts to size: 3/4-inch section from enclosure, aluminum back bezel, Lexan front bezel, heat sink slices.
53 comments
1-40 of 53next »
Jan 15, 2012. 9:36 PMmwarren_us says:
Luis Leonardo's $88 Nova Star project on Kickstarter (http://www.kickstarter.com/projects/2037357107/the-nova-star or http://www.ibikesafe.com ) looks very much like this too.
Sep 15, 2011. 2:50 AMrprough says:
The arctic silver thermal adhesive can be found on any computer supply website. www.xoxide.com for example. Just remember to get the adhesive and not the "paste" which is just for heat transfer properties that might be disassembled later.
Jul 24, 2011. 7:42 AMspaghettikid says:
Hi, I have finished this bike light, but whilst assembling the battery/bottle part the wires snapped off the potentiometer, and there is no way of re-soldering them on, is there any specific type of pot i should get??
Jun 23, 2011. 3:06 PMnerbaneth says:
Great design!
AAah! Don't insulate batteries! you want the batteries to loose heat quickly if necessary. This will shorten battery life.
May 7, 2011. 1:58 PMsnowluck2345 says:
This isn't as powerful as a 70 watt halogen. Halogens are 20-40 lumens per watt.
Apr 17, 2011. 3:26 AMspaghettikid says:
Where did you order your lenses and lens holders from, i cannot find anywhere that will only sell 3, they only accept big +50 orders.... ?
Apr 17, 2011. 3:35 AMspaghettikid says:
Found it =] RS components did them in the end, but they didnt show up on google when i searched it =]
Apr 17, 2011. 3:14 AMspaghettikid says:
Does it matter which way up the LED's go as long as the middle one is the opposite as the others?
Mar 17, 2011. 1:30 AMspaghettikid says:
For the arctic silver adhesive which glue is it exactly because they have arctic silver of several types, arctic alumina of several types, the arctic alumina is much cheaper but will it still work?
Feb 23, 2011. 1:28 PMspaghettikid says:
Hello, great instructable, i am in the process of locating the parts and the hammond enclosure is the only part i am missing, could someone give the link to it as previous links given in comments have not been the right ones or are no longer available =] thanks
Feb 25, 2011. 6:27 AMspaghettikid says:
(removed by author or community request)
Aug 3, 2010. 7:58 AMknektek says:
I went to lidl yestorday and I had found 2 'D' sized rechargeable cells for £2.50! The best thing about them is that they hold 4700 mAH each!
Jul 13, 2010. 12:55 PMGENERALCHAOS says:
... Nice and BEEFY power output im crazy about led lamps i always look for good idea like this good show
Jun 17, 2010. 7:36 PMjohny875 says:
My fav place for part is http://www.chinazrh.com They ship world wide, free of charge Read the customer reviews to avoid getting lemons thou ;)
Sep 3, 2009. 10:32 PMVspec says:
Could this be used without the power supply? like maybe wiring it into a motorcycle stator?
Mar 16, 2010. 3:16 PMSimpson_jr says:
Yes, it's possible, I was wondering whether you would need a 12 volt stator,  but according to the buck-puck specs they can handle an input of 5-32 volts _DC_.
Driving very slowly with a 6-volt stator (and no battery) might... give problems though. You might have to choose between a ticket for speeding or one for driving without light ;)
One can also ditch the buck-puck and just use a resistor. you'll need a resistor capable of dissipating a lot of power and you'll need to calculate the exact value in ohms. Just google LED-calculator to find one and enter the specs found in the datasheet of the LEDs used.  Most online calculators will  show you the schematic needed.
Most online LED calculators will start protesting that the amount of Milliamperes is very high (for a LED) or that the resistor must be capable to handle a very high wattage. That's because most of those calculators aren't written for high power leds (yet) although the outcome is correct.
I'd advice you to buy a resistor capable of handling 3-4 times the load. In most  electronics (not the extremely cheap stuff)  components used can handle at least twice the load of the design which  is indeed enough, but.... The resistor may still get very hot.
There are a few disadvantage to a set up without buck-puck, When your stator doesn't give a the same amount of volts at different RPMs, your lights will dim/brighten every time you shift gears. Although rated as an 12 volt stator it might... also generate more at  high RPMs which could ruin the LEDs.
A motorcycle with battery will give a more constant voltage and have less problems.  Anyway, measure what your stator (with or without battery) is capable of before building a resistor-set up.
The beauty of a buck-puck is that it delivers the exact amount of power to the LEDS whether the motor runs stationary or at 11000 RPM without having to know too much about electronics.
It is possible to drive leds in other ways as well, even quit cheap,  but those require a lot more knowledge about the components used.
Feb 17, 2010. 3:11 PMHellaCaj says:
How nice of our friends in China to scour sites like this for their latest and greatest "inventions." Great work Lumen.
Feb 13, 2010. 6:33 AMbronxbomber says:
The magicshine is sold out everywhere, it may be bright to specs but it is really the same as this one.  As the battery it uses is junk and goes out to battery heaven in less then a weeks time.  Now maybe if you buy just the head light and add this battery it should work great.  But this one looks more fun to build and can change led to high ones.  They do have 540 lum leds which should out perform that magic-hine and get a better batter for 80+ at the website above or build your own.  cheaper to build a battery then let them, you can save $10-30 on doing it yourself.
Feb 13, 2010. 6:23 AMbronxbomber says:
Those wanting to know more info on the case this person used here they are
Length  Width  Height
4.72      2.82      .75 INCHES
120       71.2       19  MM
with a cost of            1-5      6-49   Quantity
1455C1202BK 9C  $11.02  $9.33 each
http://www.hammondmfg.com/1455V2.htm
Photo Gallary of sizes
http://www.hammondmfg.com/1455ptbla.htm
Was a pain to find but did now to find where to get it in stock or cheaper.  But since we now have the dimensions we can find something close to it.  Since it will be cut into parts when spend the 11.02 plus shipping.
List of where to buy in different countries
http://www.hammondmfg.com/dists.htm
cheper at
http://www.mouser.com/ProductDetail/Hammond/1455B1202BK/?qs=GM6gGTqOQCuRmNe%252bgxXacw%3d%3d for $9.99
This really wasn't hard to place when you did the instructions but I would have never learned to search the web this good.
Feb 13, 2010. 6:25 AMbronxbomber says:
Those leds are being discontinued so a replacement can be found else where or oem site.
Jan 17, 2010. 5:31 PMchris2002rocklin says:
I think you look for any old aluminum enclosure. Not to defend the poor (lack of) specific build list...try mouser.com to see, they have some but not sure about sizes.
Dec 6, 2009. 8:15 PMcurlyfry562 says:
nice Job. You gotta love Hammond enclosures.
Nov 22, 2009. 5:00 AMgiesken says:
 Great job, thx
Nov 16, 2009. 5:33 PM_Scratch_ says:
The (Department of energy?) is holding a contest for a company/person to make a light bulb to replace the 60watt bulb. it has to have at least 90 lumens PER watt.... quite a bit, if you create 2500 working copys of your product, and it wins, you will win 10 million US dollars. pretty cool....
Sep 27, 2009. 2:50 PMBRAVODOG says:
Ok where do you get the Hammond enclosure ? is it a h/d one?
Sep 15, 2009. 1:57 AMpteranosaur says:
modernBIKE.com has an adaptable bracket---go to Accessories-Lights-subheading Light mounts and Brackets---cygolite Handlebar bracket @ $14.95
Sep 4, 2009. 4:25 PMqwertyboy says:
the second picture looks like a car ignition coil...
Sep 15, 2009. 1:20 AMpteranosaur says:
Just think-if you were to use a chromed 'coil cover to mount the plastic bottle...
Sep 5, 2009. 5:18 PMnightmaresyndrome says:
I'm a little confused about which buck puck to get...there isn't specifically a "1a"
http://www.ledsupply.com/buckpuck.php?gclid=CKPNzq7Y25wCFQJD5godm3iDJA
Could you be more specific about which one you got from the above page?? Does anyone else know? Theres no clear picture.
Sep 4, 2009. 6:40 AMStephen87 says:
this is pretty awesome and it also gives me an idea of how to possibly make some fog lights for my truck although I am not sure how long they can be on constantly
Sep 5, 2009. 5:19 AMSimpson_jr says:
LEDs have a life expectancy of 20.000 to 50.000 hours and you can keep them on constantly as long as that. LEDs like these do get quite hot though so a good heath sink is a must, just like the right buck-puck driver which ensures the LEDs won't get more energy as they can handle. Larger&smaller LEDs (in terms of power) are available, just as LED-drivers (Buck-puck isn't the only one), some of those can be dimmed. I've seen manufacturers started selling LED-Applications to light sport-stadiums recently, so the sky is the limit.
Sep 5, 2009. 9:34 AMStephen87 says:
Awesome, Thanks for the info
Sep 6, 2009. 9:08 AMJZ Price says:
The small LEDs last for 10 years. but the newer super bright ones are "over clocked" and don't last as long. But it isn't like they will just go out. A cool white LED will fade to a warm white (while the efficiency goes down). and go out. Different Brands over clock more than ever. OSRAM doesn't overclock at all. but Luxen overclocks a fair amount.
Sep 5, 2009. 2:06 AMcamb00 says:
Cant the back of the led short out on the metal ?
Sep 6, 2009. 7:19 AMjoejoerowley says:
Not really. It is a ground/heatsink.
Sep 5, 2009. 12:29 AMstatic says:
Stating the obvious. What is called the dim headlights on cars is actually low beam. Perhaps the ultimate would be to salvage the lens from a burned out motorcycle sealed beam, and use it as the starting point for LED bicycle head lamp. Some of the early automobiles actually physically "dipped" the headlamp automobiles, that too may be an option with LED bicycle headlamps.
Sep 1, 2009. 9:12 AMj-plan says:
firstly, awesome 'ible. this is exactly the kind of thing ive been looking to make, secondly, could you please advise me on where to get these parts? preferably in the uk :) thanks
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:700lumenLED
