3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
700-Lumen LED Bike Light
Step 5Building the Power Supply
Step 5: Battery pack is made from four 18650 Li-ion cells.
Overview: LED driver and on/off switch will be placed inside water bottle with battery pack. Battery terminal leads use a Molex connector for charging and connecting to driver.
A. Parts Needed: 18650 battery pack from Battery Space with built-in poly-switch and PCB for protection, Molex wire connectors, on/off toggle switch, buck-puck LED driver with pot for dimming.
B. Assemble the wiring harness with solder and shrink tubing. Shown in the third photo is the wiring harness; clockwise from top: dimming pot, LED driver, blue and white wires to LEDs, on/off toggle switch, Molex connector to battery.
C. I used a two-pin connector between the power supply and LEDs, but any good connector will work and preferrably one that can keep out moisture and dirt.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:700lumenLED
