74HC595 Digital LED Display Based on Arduino( Code Provided)
23,835
22
9
Posted in TechnologyArduino
Introduction: 74HC595 Digital LED Display Based on Arduino( Code Provided)
About: www.ICStation.com is a top store of electronic, which specializes in all kinds of IC products, such IC accessories, Module, Robots, Development Board, Transistor, Capacitor and so on. We're located in She...
The Chief Engineer of  ICStation R&D department Jack is using ICStation UNO R3 compatible with Arduino to successfully make the 74HC595 drive four digital LED display. We will share the schematic diagram, wiring diagram,making steps,download Diagram and  also the useful program code designed by ICStation.
When you develop a project, it often needs to make IO expansion.The 74HC595 shifting register is a good choice. Following will introduce you that use two pieces 74HC595 to realize the display system of four digital LED(of course, can also realize 8 digital LED display) .It only uses three IO (PIN2,3, 5) of Arduino.
Components list:
1. ICStation UNO development board  $12.69 ( Or Arduino UNO development board)
2.2PCS 74HC595
3.DuPont line: 30PCS
4.four digital LED display with the same anode
5. 20 PCS 20mm pin header
6.Bread board
7.USB Cable
8.4PCS 47Ω resistance
Step 1: Schematic Diagram
Step 2: The Wiring Diagram:
Step 3: To Build the Circuit According to the Schematic Diagram
Because we only do testing, maybe it is not practical.If you want it to have practical use, you should weld it manually which will make the circuit more stable. When you build the circuit by hand the pin header is needed which will help you to change the DuPont line to jumper wires immediately.
Step 4: Download Diagram
Step 5: Code for Your Reference
Designed by ICStation
#define   HC_DATA_H digitalWrite(data, HIGH)   // data line output high
#define   HC_DATA_L digitalWrite(data, LOW)   //date line output low
#define   HC_RCK_H digitalWrite(rck, HIGH)   // rck output high
#define   HC_RCK_L digitalWrite(rck, LOW)  // rck output low
#define   HC_SCK_H digitalWrite(sck, HIGH)   // sck output high
#define   HC_SCK_L digitalWrite(sck, LOW)  // sck output low
unsigned char LED_BCD[16] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e };  //common  anode digital tube BCD code
//Define the pin
int data =2;
int rck =3;
int sck =5;
// the setup routine runs once when you press reset:
void setup() {
  // initialize the digital pin as an output.
  pinMode(data, OUTPUT);
  pinMode(rck, OUTPUT);
  pinMode(sck, OUTPUT);
  pinMode(sclr, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
  unsigned char dopp =0;
  for( unsigned char i=0; i < 4; ++i)
  if(i ==3) dopp =1;
else dopp =0;
  HC_data_analyze(i,i,dopp);  //Nixie Tube display
void HC_data_analyze(char LED_number,unsigned char LED_display,unsigned char LED_dp)
  // data analyse
  unsigned int HC_DISP = 0,HC_LEDCODE,HC_LEDCODE_temp=0;
  if(LED_display > 15) LED_display = 0;
  HC_LEDCODE = LED_BCD[LED_display] ;  //get BCD code
  for(unsigned char i=0; i < 8;++i)
     HC_LEDCODE_temp <<=1;
     if(HC_LEDCODE&0x01) HC_LEDCODE_temp |= 0x01;
     HC_LEDCODE >>=1;
    if(LED_dp)  HC_LEDCODE_temp &= 0xfe;
   HC_DISP = HC_LEDCODE_temp;
  switch(LED_number)
     case 0: HC_DISP |= 0x8000;break;
     case 1: HC_DISP |= 0x4000;break;
     case 2: HC_DISP |= 0x2000;break;
     case 3: HC_DISP |= 0x1000;break;
  write_74HC595(HC_DISP);  //74HC595 shifting register  data transfer
void write_74HC595( unsigned int data_a)  //communication with 74HC595
  char look =0;
  HC_RCK_L;  //latch open
  HC_SCK_L;
  for (;look < 16; ++look)
    if(data_a&0x0001) {HC_DATA_H;}
    else {HC_DATA_L;}
    HC_SCK_H;
    HC_SCK_L;
    data_a >>= 1;
  HC_RCK_H;
This file  is download from ICstation BBS
If you have any question, please visit our BBS:
http://www.icstation.com/forum/
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    9 Comments
    Hi Friend! the following error appears:
    'sclr' was not declared in this scope
    Thank you
    I get the same error. If I comment it out, the code runs, but the LED just flashes 8.8.8.8. instead of working.
    I wrote arduino library for this display with two TM74HC595
    https://github.com/kostarev/TM74HC595-4dig-display/archive/master.zip
    Thank you, Valery. Your library works wonderfully with the module 4-digits.
    Simple and comprehensible to use. I am a 5-minute solved his problem by using your library.
    Reproduced in the article code - do not understand what. Back in the the code was a crutch for beginners! I looked for 2 hours, and did not understand how to derive other data in addition to the digits "3210", despite the fact that I have the initial programming skills. This paper is copied on multiple resource, despite the fact that it is completely useless. The usefulness of this article only to find your library.
    Last version of my library
    https://sites.google.com/site/fajlydlablogakotavpalto/123/TM74HC595-4dig-display.zip?attredirects=0&d=1
    You've missed out one wire to connect one of the 595 pin 9 to pin 14 of another.
    the code 'pinMode(sclr, OUTPUT); ' must be commented.
    it is better to use 'ShitOut()' function.
    Amusing spelling mistake :)
    Thank you for your valuable advice!
    The following is the code that has been changed.
    //Define the pin
    int data =2;
    int rck =3;
    int sck =5;
    void setup() {
    pinMode(data, OUTPUT); //initial data
    pinMode(rck, OUTPUT); //initial rck
    pinMode(sck, OUTPUT); //initial sck
    pinMode(sclr, OUTPUT); //initial sclr
    void loop() {
    if(i ==3) dopp =1;
    else dopp =0;
    LED_display(i,i,dopp); //Nixie Tube display
    void LED_display(char LED_number,unsigned char LED_display,unsigned char LED_dp)
    // data analyse
    unsigned int hc_disp = 0,hc_ledcode,hc_ledcode_temp=0;
    hc_ledcode = LED_BCD[LED_display] ; //get BCD code
    hc_ledcode_temp <<=1;
    if(hc_ledcode&0x01) hc_ledcode_temp |= 0x01;
    hc_ledcode >>=1;
    if(LED_dp) hc_ledcode_temp &= 0xfe;
    hc_disp = hc_ledcode_temp;
    switch(LED_number)
    case 0: hc_disp |= 0x8000;break;
    case 1: hc_disp |= 0x4000;break;
    case 2: hc_disp |= 0x2000;break;
    case 3: hc_disp |= 0x1000;break;
    write_74HC595_ShiftOUTPUT(hc_disp); //74HC595 shifting register data transfer
    //shift output to 74HC595
    void write_74HC595_ShiftOUTPUT( unsigned int data_a) //communication with 74HC595
    char look =0;
    HC_SCK_L;
    else {HC_DATA_L;}
    HC_SCK_H;
    HC_SCK_L;
    data_a >>= 1;
    HC_RCK_H;
