8-Bit Mario Blanket - Made From Granny Squares
317,108
450
200
Posted
Introduction: 8-Bit Mario Blanket - Made From Granny Squares
Sew Warm Contest
Second Prize in the
Sew Warm Contest
This blanket is made 100% of crocheted granny squares.  To follow this instructable, you must be able to crochet a granny square.  If you have never made one, they are not difficult, please see my previous instructable here.  If you have never crocheted before, start here.
Required Supplies:
 - 1 crochet hook, size H8/5mm (nearly any size will work, this is just what I used)
 - 4 skeins of Red Heart Super Saver, Blue
 - 2 skeins of Red Heart Super Saver, Brown
 - 2 Skeins of Red Heart Super Saver, Tan
 - 3 Skeins of Red Heart Super Saver, Red
 - 1 Large Sewing Needle
Total cost - approximately $25.00 (USD)
Step 1: Planning the Project
The first step to making this blanket is to thoroughly plan out your work.  Download this spreadsheet for a detailed layout.  You can edit this to your liking.
It is a good idea to buy all of the yarn at once.  You never know when the store may run out of a needed color and not restock.  You can buy Red Heart Super Saver yarn at most places, such as Wal-Mart, Hobby Lobby, Michael's, and more.
Step 2: Make a Granny Square
Now that you are prepared and ready, let's being by making a granny square
Repeat 251 more times :)
You can see from the spreadsheet, you will need the following quantities:
 - Brown- 54
 - Red- 45
 - Tan- 42
 - Blue- 109
Step 3: Sew Together Individual Squares Into Rows
Starting with Row one, lay out the correct colors for that row.  So as to not make any mistakes, use safety pins to attach squares.
disconnect the first two squares to be sewn together.
Lay them face to face
Using  your large needle and matching color yarn as thread, sew the squares together.  A basic wip stitch works best.
Disconnect the next square in line and sew it to the previously sewn pair.  Repeat this until all squares from the row are connected.
Sew together all squares to form all 18 rows of the blanket.
Step 4: Sew Together All Rows
Now that you have all of your horizontal rows, it's time to sew them together to form the blanket.
Lay out the rows in the proper order and inspect to make sure everything is in order.
Sew together the rows, just as you did the individual squares:
Lay rows one and two together, face to face.  Sew using same wip stitch as before.
Step 5: Crochet Binding Around Edge of Blanket
Using red yarn, do a single crochet in every stitch all the way around the blanket.
Using same red  yarn, do a half-double crochet all the way around.
Step 6: Conclusion
This completes the 8-Bit mario Blanket.  You can see some pictures of the final product here.
Also, for your consideration, here are some other famous 8-bit characters you may wish to use instead of Mario.
I hope you have enjoyed this instructable.  Please feel free to ask any questions you may have.
6 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Spotless Contest
    Spotless Contest
  • Pocket-Sized Contest
187 Comments
Anyone else struggling with varying thickness of the yarn? It's all Red Heard Super Saver, but the red & brown are significantly thicker than the blue & tan, so the square sizes are off. I tried blocking them and even using a smaller gauge hook for red & brown, but didn't have any luck. I'm just starting to stitch the rows together and I'm worried that a year's worth of work is about to fall apart :(
What size are the squares for each color?
I am working on a Mario blanket and I'm wondering what colour you used for joining? Thanks for your help!
i used the same colors as the squares ... ie a blue and blue together i joined with blue ... blue and brown i used blue or brown x
Ha ha! This is such a great idea! And your execution is fabulous. Nice work!
I finally finished my blanket!! (2.5 years later) I was getting so discouraged when I started to join things together as my squares weren't uniform, and things were getting puffy and lumpy. But then I learnt about steam blocking finished items made with acrylic yarn. Thank you so much for the 'ible =D
Did you put the blanket together and steam block the whole thing, or did you do each square individually?
Hi. Just wondering how many balls of wool you needed to make this? Thanks
That is AWESOME! I am seriously impressed. That looks fantastic! Way to go! Glad you figured out the blocking trick. I should have included that in the instructable, but I didn't have to do it with mine, so I didn't think about it.
