8 Incredible Eye Makeup Remover Hacks
 by Carleyy
Featured
Here are 8 easy to make home made hacks for removing your eye makeup! You can find all of these ingredients lying around your house and in your local health food store.
I have tried each of these on myself and they all work just as good as any eye makeup remover I have bought at the drug store. Try them out for yourself and let me know how they work for you!
Step 1: Avocados
I found a lot of recipes for eye makeup remover that called for avocado oil.  I had some avocados lying around the kitchen...thus avocado oil!
For this I just took a q-tip and swabbed the avocado.  You don't need to get a chunk of avocado on the q-tip, just coat it in the oil from the avocado.
Step 2: No-Tears Baby Shampoo
Just add a drop of baby shampoo to a cotton pad or swab to remove eye makeup.
I bought this little bottle for less than $2.  What a great deal if you consider how much money you pay for eye makeup remover!
Step 3: Hair Conditioner
You already have it in your bathroom...
Just a little dab of hair conditioner does the job!
Step 4: Shortening
Shortening?
Its just vegetable oil and it keeps your skin soft.  When your makeup remover runs out just run to your kitchen for some makeshift eye makeup remover.
Step 5: Petrolum Jelly
A little bit goes a long way!
Petrolum Jelly is a safe way to remove your water proof makeup.  Use just a small amount to remove your eye makeup then go ahead and dab some on your lips!
Step 6: Grapeseed and Castor Oil
Recipe:
3 tbsp. Grape Seed Oil
1 tbsp. Castor Oil
Mix these oils together in a cup and stir.  This is a great recipe for those with sensitive skin.
Step 7: Jojoba Oil
Recipe:
1 part Jojoba Oil
2 parts Water
Try this sustainably friendly makeup remover!  It is non-allergenic so it is perfect for use on eyes.  It can also be used to remove any other makeup.
Step 8: Vegetable Oil Medley
Recipe:
Equal parts olive oil, canola oil, and castor oil (I used a tbsp of each).
These vegetable oils blend together to create the perfect eye makeup remover!
Step 9: Final Test - Which produces the best results?
I tested all of these on my eyes but I wanted to see how they compared.
I put 8 eyeliner marks on my arm (first picture).  And then I dipped a cotton swap in each mixture and lightly rubbed it on the eyeliner ten times.  You can still see the eyeliner for each remover in the second picture because I did not wipe away the the residue after I applied it (which you would normally do with any eye makeup remover).
ANT2574 says: Sep 7, 2012. 6:27 AM
I use Huggies Baby wipe to remove my make-up. They make a cucumber scented wipe that smells nice and isnt harsh on my skin. Removes all traces of makeup!
Mauigerbil says: Jan 23, 2012. 10:27 PM
Veg oil and Grape and Castor oil tied FTW (for the win)
awilson18 says: Dec 12, 2011. 12:02 AM
I just use olive oil. It's quick, easy, and works perfectly.
lushluxelovely says: Jul 21, 2011. 11:45 AM
What I like to do is buy a small, travel sized bottle from target or walmart (they're around $1)
Fill the bottle with 1/2 witch hazel & 1/2 olive oil
Be sure to shake the two parts together before using
It makes your skin super soft and it literally removes the most stubborn makeup.
http://lushluxelovely.blogspot.com/
Victoria_Girard says: Mar 15, 2011. 10:43 AM
Great tips!  I  use sweet almond oil to take off my stubborn eye makeup.  It seems to work just as well as some of the expensive makeup removers that I have used.   I also feel as though it is nourishing and moisturizing my eye area at the same time.   But I really want to try some of your mixtures as jojoba oil and olive oil are also very good for the skin.
Thanks for the great tips.
Victoria
Publisher, http://revealgreatskin.com
Athena11 says: Oct 4, 2010. 8:42 PM
This is really great thank you so much i hate spending all that money on makeup remover that i use so much when i put somthing on and dislike it
omnibot says: Jul 10, 2010. 12:00 AM
Awesome, I know plenty of people who need to know this.
cursed_kross says: Jul 9, 2010. 10:45 PM
I love using olive oil to remove make up. I think it should also be noted that extra virgin olive oil is the best to use. Extra virgin comes from the first cold pressing of the olives and will have the most benefits, plus taste, and with each press (virgin olive oil, olive oil) it loses these benefits
scoochmaroo says: Jul 9, 2010. 5:40 PM
Awesome! And dang it, I just bought eye make-up remover. Can you believe it?? What was I thinking?!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
