3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
8' Jack Skellington Puppet
8\
Inspired by the recent 3-D re-release of the Nightmare Before Christmas and a photo of a similar puppet, this 8' Jack Skellington puppet was actually a last minute costume idea my wife and I put together on a whim over the course of a week or so. This instructable will show you how we accomplished it so you can make any large puppet based on this design, and more importanly, how you can improve on our results.
Materials:
About 50 feet of 1" PVC pipe
1" PVC pipe joints: Nine elbows, Six T joints, One cross joint
Two .5" x about 45" dowels
twine
duct tape
black felt
black foam sheets
white felt
batting/stuffing
3/4" or 1" braided elastic strap
pipe cleaners
3 or 4 yards of black pinstripe fabric
Tools:
hacksaw
scissors
electric drill
needle and thread
glue gun
exacto knife
The structure of the puppet, supports and shoulder harness consist mostly of
1" PVC pipes and joints (you might notice a 1.25" cross joint in the chest in
my photos -- Home Depot was out of 1" cross joints, so I used this with some 1"
to 1.25" couplers instead.) The PVC can be cut with a hacksaw with little
effort, and I drilled through with just a regular drill bit -- whatever came
with my wife's drill. Remember to take into consideration that about .75" of
the pipe will overlap with the elbow, T, and cross joints when designing your
puppet.
Step 1Construct the skeleton
The skeleton starts with a large cross built out of the cross joint and 4 pieces of pipe: neck, shoulders, and trunk. (See scale drawing here for our lengths -- we wanted our Jack to be 8' tall with his legs bent.) Plan on the neck pipe extending all the way through to the top of the head, actually slightly longer than in the drawing. Also, it's not reflected in the drawing, but I cut a section out of the trunk pipe a few inches below the cross joint to insert a t joint and cut a few inches off the bottom of the trunk for another t joint -- these joints will connect the skeleton to the harness later.
35 comments
May 6, 2012. 8:20 AMlukev2 says:
this inspired me to make this:
May 22, 2012. 5:07 AMlukev2 says:
the hands were my neighbors old giant troll costume gloves, and the frame was made with bamboo, and it was covered with new trash bags. the head is an old lamp i found in the trash, which i gave a new orange paintjob, and then i misted the orange paint with black, so it looked distressed, i also colored the inside black, so it would look dark and deep.....
Sep 19, 2010. 4:18 PMdrahcus says:
could you tell me the approximate lengths of each piece of PVC?
Jan 22, 2009. 4:20 PMMr. Brownie says:
I'm sorry, being a NBC nerd, that doesn't look to much like Jack.
Sep 23, 2009. 4:27 PMeulaliaaaa! says:
I think it looks pretty accurate.
Sep 10, 2010. 4:30 PMeulaliaaaa! says:
The fingers are a little short and plump though... You should go around town singing "Jack's Lament"!
Nov 9, 2008. 12:21 AMtrebory6 says:
OMG. This is an amazing Idea. If you don't mind, i think I might modify a few bits of the Design. For one, the harness is slightly too bulky. So I was thinking about what if you modified a Marching band Drum harness like this one: *Harness*.
And then, instead of attaching the feet directly to your feet, what about attaching the feet a little bit away from your own feet and have shoes that have a little thing in front where jack's feet attaches to(if that made any sense.).
Finally, Articulated hands. Using the same principle as Articulate Hand Instructable, have articulate hands. This would be fairly easy.
I have been trying to think of a way to make the mouth be able to open, but unfortunately, I have no conclusion due to the fact that while operating this puppet, you will have all your arms and legs busy. And you could use your head, but It would become uncomfortable after a while having to move your head. In the end it might look like an epileptic guy is stalking Jack Skellington.
I guess you could turn to a mechanical aspect of making his mouth open, but I would like to keep this away from electronics.
I am going to be taking this out to Comic-con!
Nov 9, 2008. 12:24 AMtrebory6 says:
I just realized I sounded a bit judgy. Sorry about that, didn't mean to come off that way. This was really a great idea. It is a heck of a lot better than this costume! lol
But really, amazing job.
Oct 31, 2008. 3:20 PMbryandhispup says:
This was a FUN Build! Totally easy, I modified it to be a Scarecrow and modded the harness a bit. He will be used over and over for years to come as it is basically a perfect skelliton starting point. Hoping to get alot of smiles and hugs this year. I will be experimenting with the leg joints a bit. and I already modified the arms. I used the PVC for the upper arm then placed a T Joint at the elbow. I used 1" dowel rods 36" long and used 21" for the arm and the rest that hangs out the back made perfect controls. put in a screw on either side to hold it in place. Now you have pivot, BUT the arms are stuck at 90 Degree angle. WORKS GREAT! Thanks Again!
Nov 12, 2007. 6:10 PMDoctor What says:
gonna sound stupid, but how much does 1" pvc cost per foot?? i usually just use the stuff at my stepdad's work, but they don't have fifty feet.
Oct 31, 2008. 3:22 PMbryandhispup says:
3.00 US for 10 feet. give or take a dollar or 2
Nov 14, 2007. 6:34 PMDoctor What says:
thanx. that means, about 15.90 for fifty feet. not too bad at all.
Jul 25, 2008. 12:21 PMGage987 says:
ok if you have kids that trick or treat since you used the silver pinstrips you could wear all black and paint yo pipes and walk with yo kids to make it more hallo-weenie
Mar 23, 2008. 8:56 AMCapnTac says:
I'm working on making a smaller hand puppet version of Jack. NBC is my favorite stopmotion animation movie ever!
Mar 28, 2008. 3:51 PMCapnTac says:
Maybe soon. I'm still looking for that freakin' glue gun I had lying around. But when I'm done and satisfied, I'll make an instructable.
Jul 19, 2008. 10:31 PMxwx says:
wow this is cool just too bad you couldent find some black n grey pinstripe material anyways NBC is my favorite movie in general :D
Feb 29, 2008. 10:24 PMbcr8ve says:
Oooh! Guess who's going to be loitering on my porch come October.... This is great! Thanks for posting it!
Dec 16, 2007. 9:11 AMSkellington says:
Cool instructable (I'm not saying that just because I love the movie, either)! You should do a short puppet show.
Nov 9, 2007. 11:10 PMSHIFT! says:
I should try this with a BoneJangles puppet....
Nov 28, 2007. 2:41 PMSHIFT! says:
Black lights and Glow in the dark would be great for BoneJangles (like in the Remains of the Day song), but would alsogreat for an Oogie Boogie puppet as well. And with 8 feet, it would be so lifelike!
Nov 6, 2007. 2:21 PMjoknrok says:
Fantastic! I love it. It would be great to see a video of it in action. One question: Why did you have the legs bent all the time instead of having them framed out from your body like the rest of him so they look like they are walking? Anyway, I think I know what I'll be for next halloween. Great job!
Nov 11, 2007. 6:26 AMcarpespasm says:
I think you could have just twined another peice of pipe between the femur pipes to keep his legs spread apart some while keeping them able to move around mostly free of one another. Aside from that I'd just paint the frame black so it's less noticable. Great work on it as a whole though, the cat's head was a nice detail and the whole thing is very clean looking.
Nov 9, 2007. 1:51 PMDoctor What says:
Yay!! i have an aunt that works at a craft store, so i can use her discount. but on the joints, could i use anything except twine, it doesn't seem too practical.
Nov 7, 2007. 4:41 AMHonus says:
Wow! That probably looked fantastic going down the street at night- especially when you're dressed all in black. I saw a guy that made a StarWars General Grievous puppet costume using a similar method.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:novelgazer
