8 Player Quizz Buzzer System Using Arduino
3,108
14
6
Published
Introduction: 8 Player Quizz Buzzer System Using Arduino
8 player quiz buzzer can be used in various competition organise in school and colleges to identify the team who has pressed the buzzer first.
Advantage of this quiz buzzer circuit is once a team has press the switch others team may press the switch but only number. displayed on display who press switch first. So with the help of this circuit we can easily identify the contestant who has press the switch first. Let build the circuit using a ARDUINO NANO which read the input from push buttons and displays the corresponding number on a display device. It is a simple circuit with minimum number of components and easily can build. The ARDUINO takes into account the time delay between two buttons and the accurate number is displayed. When one of the buttons is pressed, the buzzer starts ringing and the corresponding number is displayed on the 7 segment display.
Step 1: Components:
1. Arduino Nano or any
2. Push Buttons x8
3. Resistors x8 2.2Kohm
4. Resistor 220ohm 1watt
5. 7 Segment Display
6. Male Female headers
7. Buzzer
8. 2N2222 npn transistor x1
9. Resistor 1kohm
10. 9v Battery & connector
11. Dot matrix PCB
Step 2:
Step 3: Circuit Diagram:
Here in circuit we are not using A6 & A7 pins of nano because there is no digital circuit present internally in the chip.
Step 4: Coding:
int x=1;// take int value as 1
void setup()
{ pinMode(A0,INPUT); //analog pins as input
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(A3,INPUT);
pinMode(A4,INPUT);
pinMode(A5,INPUT);
pinMode(0,INPUT); //digital pins as input
pinMode(1,INPUT);
pinMode(12,OUTPUT); //Digital pins as output for seven seg display
pinMode(11,OUTPUT);
pinMode(10,OUTPUT);
pinMode(9,OUTPUT);
pinMode(8,OUTPUT);
pinMode(7,OUTPUT);
pinMode(6,OUTPUT);
pinMode(3,OUTPUT); // output for buzzer
// set initially display to 0
digitalWrite(12,HIGH); // seg a
digitalWrite(11,HIGH); // seg b
digitalWrite(10,HIGH); // seg c
digitalWrite(9,HIGH); //seg d
digitalWrite(8,HIGH); //seg e
digitalWrite(7,HIGH); // seg f
digitalWrite(6,LOW); //seg g
digitalWrite(3,LOW); // buzzer as off
void loop() {
int a=digitalRead(A0); // reading pin values for 8 buttons
int b=digitalRead(A1);
int c=digitalRead(A2);
int d=digitalRead(A3);
int e=digitalRead(A4);
int f=digitalRead(A5);
int g=digitalRead(0);
int h=digitalRead(1);
if(a==LOW) //if 1 player press button
{ if(x==1) // check if x is 1 if yes then execute the code
{ digitalWrite(3,HIGH); // buzzer on
digitalWrite(11,HIGH); // pirnt 1
digitalWrite(9,LOW);
digitalWrite(8,LOW);
digitalWrite(7,LOW);
digitalWrite(12,LOW);
x++; //increment x
else if(b==LOW) //if player 2 press button
{ digitalWrite(3,HIGH);// buzzer on
digitalWrite(11,HIGH); // pirnt 2
digitalWrite(6,HIGH);
digitalWrite(10,LOW);
x++; } }
else if(c==LOW) //if player 3 press button
digitalWrite(11,HIGH); // pirnt 3
x++; } }
else if(d==LOW) //if player 4 press button
digitalWrite(11,HIGH); // pirnt 4
x++;
else if(e==LOW) //if player 5 press button
digitalWrite(10,HIGH); // pirnt 5
digitalWrite(11,LOW);
x++;
else if(f==LOW) //if player 6 press button
digitalWrite(10,HIGH); // pirnt 6
digitalWrite(11,LOW); x++; } }
else if(g==LOW) //if player 7 press button
digitalWrite(10,HIGH); // pirnt 7
x++;
else if(h==LOW) //if player 8 press button
digitalWrite(10,HIGH); // pirnt 8
x++;
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    3 Questions
    Hi, what about the 220ohm resistor, where it is get connected? The circuit diagram did not
    show this resistor?? Pl help
    Instead of seven segment display, is it possible to use LEDs for each participant? What changes in the circuitry will be required for that?
    Yes it is possible and very simple to do. You need leds which will be connected to digital pins and make it high when button is pressed.
    I want to use common anode 7 segment display how to change this program
    6 Comments
    Just write LOW on the place of HIGH for pint of 7seg display.
    Reset by using on board button of arduino nano.
    Hello,
    I am a beginner. Could u please tell me why you have used a 9v battery here?
    Can we do this without using that. Also, in the diagram, the negative edge of the battery is not clear, where it is connected ?
    With Regards,
    Faaltu_77
    9v battery is used for power supply, you can use 5v to 12 v power supply. Any power supply you can use. Negative terminal of battery is connected to common terminal of 7segment display, arduino nano gnd terminal, npn transistor's emitter terminal and to all push buttons.
