In other words, can I make a personal 8 track player with just headphones in the style of a Walkman?
How small can I make it? Bear in mind it needs quite a bit of power to move the tape loop around inside the cartridge.
Before anyone asks what the point is, it is to see if I can do it, just like most other things I make. I accept this one is only of super-niche interest.
A couple of years ago I bought a really cool "Lear-Jet" 8 track tape cartridge player and got it working for an old car. These preceded cassette players and were unusual in that the tape runs in a continuous loop - you cannot fast-forward or rewind them like a cassette. They were the first usable in-car entertaiment device and sold mainly in the US. After doing more research I found out more:
a) The cartridges had reputation for jamming and sticking. However the internal mechanisms can usually be restored to work properly.
b) The tape moves much faster past the tape head than in the later cassette tapes. This is so the "hiss" becomes higher frequency than you can hear, necessary as Dolby hiss reduction did not come along until later.
c) Therefore, with a high-end 1970's indoor HiFi player, the sound quality can actually be very good.
d) No matter how old they are (1970's and early 80's) the actual tape itself does not degrade much. I have some that sound stunningly good against all expectations.
e) I like 70's rock!
I would recommend younger viewers to read around this subject, the history of the 8 Track player is an adventure in itself featuring people such as William Lear of Lear-Jet fame and "Mad-Man" Muntz, an early affordable TV pioneer in the US.
Everything you may want to know can be found on these pages, especially the first one:
http://www.8trackheaven.com/
http://www.recording-history.org/HTML/8track1.php
http://inventors.about.com/library/inventors/bllear.htm
http://www.freeenterpriseland.com/MUNTZ.html
Remove these ads by
Signing UpStep 1Step 1
1) Get hold of an old cassette tape Walkman.
2) Buy an old car 8 track player. Cheap as chips on eBay. You just want this for the chassis, tape head and motor/flywheel assembly. So long as motor spins it doesn't matter if circuit board no longer works.
Dismantle:
1) Take circuit board out of the Walkman. You are only using the audio amplifier so gently remove/cut away everything that relates to the motor drive in the Walkman. The Walkman circuit board is now uppermost in this photo - transplanted into my creation.
2) Take a very good look at how the tape head in the Walkman is connected to its circuit board. There is a ribbon cable with 3 flat "wires" in it. One is to ground, one takes the left signal from pickup head to circuit board, one takes the right channel. There may be another wire to the outer case of the pickup head itself. You are going to wire up the pickup head in the cartridge player to the Walkman circuit board in place of the Walkman pickup head. The Cartridge player pickup head is essentially a larger older version of the one in the Walkman and the wiring is the same. You need to copy the wiring arrangement you found in your walkman.
recording tape as the car units, were in my day (the 1970's) a necessary
part of any serious music setup. You can still occasionally find good working
units in second-hand stores.
I've never taken an 8-track tape out of its car player cassette and spooled it on
a reel to play on a reel to reel unit, but I'm sure it can be done. The sound
was always potentially better than 1/8 inch cassette tape. If you own a lot of old
8 track tapes you might consider looking for a reel to reel machine and splicing
the tapes together for playing. As I recall, a full 50 ft. reel gave about 2 hours
of continuous good quality music - a retro party machine.
I also thought of an auto-loader for the tapes like the magazine from a gun but actually they did make machines like this in the 70's!
http://home.att.net/~uncamarvy/HighwayHiFi/highwayhifi.html
On the walkman theme, Audio Technica did try to make a record-player-walkman called the "Sound Burger." I even remember seeing it in the shops.
http://www.retrothing.com/2005/11/sound_burger_vi.html
John
Still awesome, just thought I'd adjust your history for you =)
I spent most of my youth listening to LP's and compact cassette recordings made from them then CD's as an adult.
Am amazed how good 8 tracks sound when looked after and played using a good machine in that warm analogue way!
John
I haven't come back to look at this for a while, thanks for all the comments.
What I would really like to do next is build a machine where the the 8 track cartridge clips to the front surface. A complex mechanism a bit like that in a VHS video tape player then pulls out a loop of tape so it can run between a high quality motor, large pinch roller and quality pickup to give a real high quality sound and a great looking machine.
