3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
800watt, 12' long 16" diameter Bass Cannon.
Step 3Cut the sub woofer mounting flanges
The flanges are used to mount the driver and also to couple the two tube sections. The following description is kinda general as if you make one of these, your dimensions will be different to match your tube and your driver.
I used a circle cutting jig, consisting of a strip of ply with the router mounted on one end. This was nailed to the centre of a board of 1/2" ply which would become the first flange. I began to cut out a the diskusing a 1/4" bit at 10" radius to give a 20" flange disk.
Starting from the outside of the flange in, I cut out the perimeter.
Then cut a 1/4" wide groove 1/4" deep at 8" radius for the top half of the sonotube to sit in. This is where the cut is concealed, and also provides a little extra surface for the adhesive to bond and create an airtight seal.
Then I flipped the disk over and cut a 10mm deep groove at 7.5" (I love changing between metric and imperial) then another 2 at the same depth inside that, which makes a shoulder for the driver to sit in.
The next cut is just inside the last to go all the way through to remove the centre section.
The second flange was identical.
Again I have drawn a cross section of the flange piece.
I then clamped the two flanges together and drilled 4 x 3/4" holes with a spade bit for the bolts to hold the two flanges together. When drilling through ply (or any timer) with a spade bit, keep an eye on the underside and when the point of the bit starts to emerge flip the piece over and finish the hole from the other side. This will prevent tear outs and give a nice clean hole..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:NastySpill
