Step 4Install the sub woofer.
I screwed the sub woofer securley onto the lower flange, added the second flange ontop then added the second length of sonotube.
I worried that the wind would possibly snap the tube out of the 1/4" grooves so re enforced the tubes with ply triangles made from scraps.
I used marine Sikaflex to glue the tube into the grooves, then screwed the ply rib triangles from inside the sonotube. I used more sikaflex to bead between all the support ribs. It ended extremely strong.
I did have to drill a hole through the lower flange to let the sub woofer cable pass through. This was an oversight. In future I'd run the cable to the sonotube wall and pass through to lugs on the outside.
The travel of the subwoofer is equal in each direction so you get equal sound in each direction.
