8051 C Development Using FREE Compiler SDCC
Introduction: 8051 C Development Using FREE Compiler SDCC
SDCC is a free and open source compiler for 8-bit mcus.
this instructables tell you:
how to install sdcc compiler;
how to use sdcc to compile a 8051 c program;
how to use a makefile for sdcc program;
Not tell you:
how to write a program in C;
how to download to program to the MCU;
Step 1: Download and Install
download sdcc from : http://sdcc.sourceforge.net
windows users have to download unxutils in order to use makefile: http://unxutils.sourceforge.net
BTW: while installing, select "add to system path".
after that, open a commandline, input:
you should see something like below picture;
if you get: command not found. this means something is wrong. most likely that the program is not added to the system path.
Step 2: Doc Structure and Makefile
their are 4 forlder and one makefile file.
hex folder-- compile result.
inc folder-- include files folder
obj folder-- object files folder
src folder-- source files folder
the makefile can scan the src file, compile the src/*.c file to one hex file in hex folder.
usually the only thing in makefile need to be changee is the TARGET.
which means the hex file name.
the sdcc_hello_world.zip is the makefile and test files.
Step 3: Write You Code and Compile
touch(make a empty file ) a test.c file in folder src.
write some test code like that:
void main()
{ while(1); }
save the file.
and type make on the directory where makefile exist.
something like that may show up, which means you have compiled you file correctly.
Step 4: DONE
I have put the test file into a zip file, so that you could download and try easily.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
