3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a 8x10 L.E.D Matrix
Step 6It's done
It\
Now you can try and make your one patterns and images and you will know how to use the 4017 IC
and the 74HC595 shift register.
12 comments
Apr 4, 2011. 2:27 AMberniech says:
Nice project, it works nicely in 8 x 10 matrix and I try to extend it in a 15 x 10 matrix, daisy chaining 2 shift registers, but it doesn' work! could you help me, showing your way of connection?
Thank you
Apr 4, 2011. 10:55 AMberniech says:
Many thanks for your answer! II'll try according to your 24x6
Mar 16, 2011. 8:47 AMdreadnought12 says:
what if i used source boost IDE for the programming? how can i program it? what codes should i use?
please reply.. i need your help :))
Jun 2, 2010. 2:18 AMKcPower says:
is there a way to make it bigger? (like 20x15)
Feb 20, 2010. 5:03 AMpickle_64 says:
Hi, i'm currently building your instructable and hats off to you, it's very detailed and easy to understand.
If i wanted to make it portable, how could it be programmed and run with arduino constantly there?
is this possible for batteries, etc...
Feb 21, 2010. 1:49 AMpickle_64 says:
how could i do this without the arduino? i have one, i'm just considering puting it into a card for a special someone...
Aug 14, 2009. 11:17 AMMultiViews says:
Hi, i'm a noobie in this section but the transistors have 3 pins. How are they connected and where is "Reset", "Clock", "Clock inhibit" & "Carry out" connected from the 4017 () I don't know if they have the right name but i hope you understand :)
Aug 26, 2009. 8:16 AMInfamousKirch says:
Methinks the best way to explain the way the transistors are working in this is that they are being used as a switch, when a voltage is applied to the BASE it's allows current to flow from the COLLECTOR to the EMITTER, when the voltage is removed from BASE, the COLLECTOR and EMITTER disconnect.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:Syst3mX(Vadim)
Electronics and LEDs what can be better ?! :D
