Introduction: 888-606-4841-Error "Windows Cannot Find Wuapp.exe" and Its Workaround in Windows 10
Windows 10 is probably the most popular and successful member of Windows-series, having a number of advanced features and applications that have given a new edge to the users’ experience. But most the users have reported some technical problems while updating or installing the operating system on their personal computer system.
Sometimes, when you click on Windows Update in the Tools menu in Internet Explorer, you come across an error message that reads as "Windows cannot find wuapp.exe." Though the error message doesn’t indicate toward any technological inability of Windows 10, yet it requires you to visit Windows technical supportpage to get troubleshooting help on Windows 10 error "Windows cannot find wuapp.exe."
The error takes place when Windows Update page launcher tool, which was in the previous version, has been deleted in the latest edition, but IE 11 that you are you using currently still locates the files.
You can launch Windows update page through several methods, for example going through the path: Start -> Settings -> Update and Security. Or, you can also create shortcut using the following command line:
· control.exe /name Microsoft.WindowsUpdate, or
· ms-settings:windowsupdate
Here are some simple steps that how you can restore the functionality:
Step 1: Create a Vbscript file
Launch Notepad; copy these two lines, mentioned below, and save the file as WULaunch.vbs in your Desktop.
· Set WshShell = WScript.CreateObject("Wscript.Shell")
· WshShell.Run "control.exe /name Microsoft.WindowsUpdate"
Once you create and save the file in desktop, you should move it to the C:\Windows directory.
Step 2: Change Wuapp.exe app path to point to the script file
Copy the following lines to Notepad –
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\wuapp.exe]
@="c:\\windows\\wulaunch.vbs"
Now you need to replace the text HKEY_CURRENT_USER with HKEY_LOCAL_MACHINE so that you can make it applicable for all users. Once you change the text, save it with .reg extension, and double-click the file to execute it.
Launch the Run dialog box and type wuapp.exe to run the command. It will actually execute the script file that in turn will start the modern Windows update page.
So this is how you can fix the error "Windows cannot find wuapp.exe." in Windows 10. If the procedures mentioned above are working out, you should access tech support solution offered by third party technicians. If you need Windows tech support phone numberdial here for Microsoft professional support services from certified Windows technicians.
Intelli Atlas is a well-known tech support company that offers the best support to all sorts of technical problems diagnosed in your Windows 10 OS. Visit technicians at employed by Intelli Atlas and get your problem resolved immediately at an affordable cost.
