Introduction: 888-846-6939-Most Common QuickBooks Errors and Error Codes
No matter how advanced a software suite is, every software package is exposed to some common technical errors. In QuickBooks, it is no surprising to encounter some technical problems while managing accounts using QuickBooks accounting software suite.
The issues are fixed immediately; provided that you have selected a right technician. Regardless of going for a lengthy procedure, you would better select a third party technical support company and get your problem resolved at the same time. To fix QuickBooks errors visit here for troubleshooting steps from certified QuickBooks technicians at third party technical support companies.
Here are some common error codes that you may come across at any point in time, when you open QuickBooks:
· QuickBooks – 6000: Error 6000 takes place when QuickBooks is opened, backed up or restored.
· QuickBooks – 6000 – 77: Error 6000 – 77 happens when QuickBooks tries to read a company file saved on an external media.
· QuickBooks – 6000 – 80: Error code 6000 – 80 comes on the computer display when QuickBooks tries to open a spoiled company file.
· QuickBooks – 6000 – 82: Error code 6000 – 82 occurs when QuickBooks accesses data files saved on another personal computer.
· QuickBooks – 6000 – 83: Error code 6000 – 83 happens when the accounting software attempts to read company file without having been installed completely.
· QuickBooks – 6000 – 301: Error code 6000 – 301 is seen when the software try to access company file saved as encrypted copy in the same location.
· QuickBooks – 6000 – 816: Error code 6000 – 816 happens when QuickBooks tries to read those company files which are being used by other users at the same time.
· QuickBooks – 6123: Error code 6123 comes on the computer screen while opening a company file over network either in multi-user mode or in the course of restoring backed up file.
· QuickBooks – 6073 – 816: Error code 6073 – 816 takes place when the accounting software encounters technical problems in opening a particular company file that is restricted by the administration.
These are some common error codes that can happen at any time when you work with your QuickBooks accounting software. For help on QuickBooks error 6150, visit website for more advanced troubleshooting steps from Intuit itself.
Else you can also approach an independent technical service provider for a quicker and more accurate support for your QuickBooks software.
Before starting the troubleshoot process, it is necessary to make sure, the software is updated to the latest version. You need to download “QuickBooks File Doctor” tool that detects any damaged QuickBooks data files and fix the same with high accuracy.
