Introduction: 888-846-6939-Network Security Prevents QuickBooks Point of Sale From Opening
QuickBooks accounting software, similar to other software suite, is incredible only when it is flawless and is not slowed down by any additional issues in the personal computer. But, generally, a software suite can hardly run flawlessly because of the code and framework it is based on. Likewise, your QuickBooks is also exposed to some specific technical errors caused by one or another reasons.
Network security preventing QuickBooks point of sale (PoS) is one of the most common issues that can come in way when you would try to open or launch any application on the accounting software. In such conditions, you should dial QuickBooks point of sale support number and access a reliable technician who can help you in a real time.
When you try to open QuickBooks point of sale, it may display an error message: Connection failed. As the QuickBooks technicians believe, improper configuration of firewall or network security can stop some of the important features or services if it finds anything threatening to the computer system. But it can be addressed easily if you configure the firewall in accordance with the accounting software.
Why the issue takes place?
· Corrupted entitlement for point of sale.
· Outdated edition of QuickBooks PoS.
· Third-party network security is preventing some features from functioning.
· Missing QuickBooks files.
Here are some important tips that you can execute to address the problem if the QuickBooks PoS is not explored to the fullest. If you don’t find it easy to run, you would better dial toll-free technical support phone number and select a certified technical team for QuickBooks help on Point of sale offered by independent tech support companies.
First of all, configuring firewall and network security in accordance with the QuickBooks files is a recommended step that can potentially help you fix the problem. Reach out to a reliable and certified QuickBooks tech professional and get the network security software configured accordingly.
Rename the WSActivity File at your client workstation
· Open Windows Explorer.
· Click the Computer folder and explore C:\Documents and Settings\All Users\Application\ Data\Intuit\QuickBooks Point of Sale XX\Ini\ (here XX refers to the version of your PoS).
· Now do a right click on WSActivity and select Rename in the drop-down list.
· Rename the file with OLDWSActivity and save it.
If the issue is still there, you should delete the entitlement client folder in your workstation. And launch the Point of Sale to check if the changes that you have made are working out.
