loading
I was in need of an instrument rack to hold all of my music equipment, however I was not willing to pay about £60 for one. I discovered the IKEA LACK rack, made from a coffee table. On going to IKEA to buy one, I was a bit disappointed as the LACK coffee table is very big for what I need, and also the construction quality is rubbish - the legs are made from a honeycomb cardboard structure and are very flimsy. However later on I saw the RAST bedside table. Upon measuring it, I was very happy to discover it was 19 inches inside - the exact dimension for rack mount gear. I bought one and took it home to find it was perfect for a rack. It is made of solid pine wood so it is very sturdy, but also attractive. There is also a very handy shelf on the top to put other bits of gear such as mixers, drum machines or effect boxes.
You can stain or paint it as you like. Unmodified, it can only hold 6 rack units, but if you lower the shelf, you can hold up to 8. The final cost of this project is about £25.
Step 1: Shopping list
Materials
RAST bedside table from IKEA - £9.00
Pair of 8U or 6U rack-strips - £7.00
(Depending on how many units you need). I bought this from eBay, but you may be able to find it in a music shop. Alternatively you could just saw up two lengths of wood and screw the instruments into these using wood screws.
Rack nuts and bolts - £3.00
Again, I bought these on eBay, but you'll almost certainly be able to buy them at the same place you buy the rack-strips.
Various wood screws - ?
You'll need a few short wood screws to secure the rack strips to the table. I also needed four long wood screws to secure the newly-lowered shelf (not necessary if you don't lower the shelf!) I already had all of these screws.
Furniture castors - £5.00
I already had these left over from a desk I was throwing out, but you'll be able to get them at a hardware store.
Tools
  • Drill and drill bits
  • Screwdrivers
  • Pencil
  • Ruler
<p>They seem to have stopped selling the as the night stand in the UK from what I can see. Gutted! Anybody know of any alternatives?</p>
<p>I've seen people do similar things with the LACK tables, but I prefer the look of this RAST table. I'd also like to know of any alternatives?</p>
<p>Please ignore the mess of cables and ill-advised paint job. This works great, I made one and I'll likely make another one or two for other locations at home.</p><p>I used </p><p>http://www.amazon.com/Reliable-Hardware-Company-RH-8-SRR--Space/dp/B00JQYUEA2/ref=sr_1_1?ie=UTF8&amp;qid=1454078071&amp;sr=8-1&amp;keywords=8u+rack+rails for the rails and it's perfect.</p><p>Great work and thanks!</p>
<p>Thank you very much for the inspiring idea - I made one of these IKEA-RAST-RACK-CASE of myself today. Took me only about an hour!</p>
<p>I like what you've done here! It reminded me of a set up I did a few years ago...not as portable as yours and more retro...you might like a peek: http://www.instructables.com/id/Retro-Sound-Desk-from-a-Low-Boy/</p>
<p>I am going to build a Slant Top case with this as the foundation, then I will wrap it with wood. joey.mclennan, I see the units screwed in with the top picture. The bottom picture is the back.</p>
<p>Hey man! Cool project! I noticed that the units aren't screwed into the Rast wall. Did you use Rack Rails?</p>
<p>Hi there,</p><p>great project, I'll do the same in a few weeks time... still got one question: why didn't you use the IKEA-screws when you lowered the shelf?</p><p>Thanks,</p><p>F.</p>
With the shelf lowered for 8U, the supplied screws were too big to not split the wood on the sides. I've since raised my shelf back to 7U, so I've gone back to using the stock screws.
Ah ok... I see.<br>Well, I was now thinking that I might as well try to not use the lower shelf at all and simply have the lowest unit hold the RAST together. What do you think of this?
<p>With some rack gear in there, that alone should provide adequate stability - you'll be fine.</p>
<p>Hey, do you happen to know the sizes of everything you used? the size and length for the shelf screws as well as the rack screws? I would also like to know what size bit you used. </p>
<p>Do you think this would be sturdy enough to handle rackmount servers? I'm helping a colleague build a server rack for a couple servers, as well as switches, perhaps even communications gear.</p>
<p>Check out the LACK tables from IKEA. Great for DIY server racks. I'm building one myself right now. You can pick one up for 8 bucks. Sturdy and the perfect size. </p><p>http://wiki.eth0.nl/index.php/LackRack</p>
hahaha... not lately but I have used it in the past... I mainly use the software versions these days, fm8
wtf... why is the photo in landscape?
Great work - looks really professional. <br>By the way - nice Yamaha TX81Z. (been using the 'lately bass' preset by any chance?)
Great idea! I made one. See image (((-:
Nice work only changes I would make are: Use wheels with screw plats ( single hole wheels as you have them tend to break out of the wood ), after you tests fit everything GLUE&gt;&gt;&gt;GLUE&gt;&gt;&gt;GLUE all the joints, add a work / night light and you have the works. <br>Hitting the parts box and IKEA this week :-) <br>Keep it coming
Five stars, and fav'ed. Great project.
Talk about a perfect fit! Beautiful!
I could not believe it when I found out it was spot on perfect for 19&quot; rackmount gear. I can only assume that the IKEA designers are secretly designing the furniture with other uses in mind...
About This Instructable
169 favorites
License:
More by Harrymatic: 8U Rack Case From IKEA RAST Table VS1103b MIDI Synthesizer Replacement Keyboard Legs
Add instructable to:
