Step 3Making a Bellows
but a bellows gives this camera foldabilty , multiple focal lengths{like a zoom lens} and just looks so cool.
now im not going to go into microscopic detail on how to make a bellows cause ive already done that here..... http://www.instructables.com/id/EDITKGPCR7EP28788U/ ....but i did take some pictures and also came up with an alternate method to score the fold lines.
heres a quick rundown of the steps
the first step is to cut the sheet of bristol board into 4 equal sections.
then you need to score parallel lines in it one half inch apart (this is to make it easy to fold)
then you decide if you want straight or tapered bellows{stick with a straight one until you have made at least one}.
measure how big your bellows needs to be and make your sides one half inch less than you need {the folds will take up the rest..there is a real danger of making your bellows too large for the box}
lay out two adjacent sections side by side 1/2 inch apart but with the lines matching.
using the hockey tape {this is the trickiest bit} carefully cover the joint between the sheets keeping them parallel .
then turn the sheet over and tape the other side of the joint so you should have two sheets with a 1/2 inch gap covered in cloth tape{duct tape will not fold up correctly but it can be used in a pinch}.
now join the third and fourth sides to the others in same way.
when its time to close the fourth side to the first place the tape on one side from the bottom or inside of the sheet gently position the other side then when its right and aligned press it down and put the last tape on top .
now what you should have is a square box about 11 inches high by 7.5 inches wide and 9.5 inches wide.
next you need to fold over one of the top edges turn the assembly 90 degrees then fold the next top in the opposite direction from the first one. once you have folded all the way around start on the next line down and fold it in the opposite direction from the fold above{i suggest you practice first or read this http://www.instructables.com/id/EDITKGPCR7EP28788U/ } much better detail there really
the new way i had of scoring the lines involves the paper cutter in the pictures
it has deep slots at 1/2 inch intervals that are square with the top bar . by holding the sheets onto the cutter i was able to score the lines using a dead ball point pen as a stylus{the pen came back to life during this step and i made a mess over myself lol].
i dont think its likely many people will have such a thing but i thought id mention it
Add Comment
