8x4=2 (2 Tables from 1 sheet of plywood)
Use a simple template to create 2 tables from a single sheet of 24mm ply or 1 table from a single sheet of 12mm ply.
We use an early version of this table as work benches in our studio. We had them laser cut out of oriented strand board, sometimes known as stirling board.
In retrospect we realised that water jet cutting would have been a better option - the 'burned' edges from the laser cutting look quite cool but tends to leave you with black marks on your hands.
Step 1Download the cutting template
If you want to cut the table by hand then download the 1:10 scale pdf drawing
or the dimensioned 1:10 scale pdf drawing
Alternatively you can use the dxf cutting template and have the timber CNC cut, laser cut or water jet cut.
I will add some links to waterjet cutting people here soon.
29 comments
Sep 19, 2010. 5:52 AMPikminRed says:
Woooo hoo! I never knew eight times four was two! Anyway great idea with the way the table fits together. 5*
Dec 17, 2011. 5:37 PMemihackr97 says:
it's cause you got ur units wrong, it's 8 ft. times 2 ft. equals 2 tables.
Dec 7, 2010. 5:42 PMtechfix1 says:
This is one nice looking table and practical!
Nov 23, 2010. 6:17 PMM4industries says:
I wouldn't do this with a laser. Plywood is too thick for the Zing 24.
Feb 17, 2009. 12:12 PMmacrumpton says:
Great tables. The only thing I would change would be to instead of both leg sets having one leg tilting in and the other tilting out I would have both legs tilt in on one set and both tilting out one the other, and then I would swap one set of legs with the other table so one table has all the legs tilting in and the other table legs tilting out. Did that make sense?
Apr 11, 2009. 2:17 PMGeeDeeKay says:
There is one more element that needs to be changed with this idea. Make sure that the opposing set of legs has the notch swapped where the pairs are joined in the center, so one set of matching legs has a notch on top and one has a notch on the bottom.
Apr 7, 2009. 5:36 PMtrialex says:
You should enter this project in the "Going With The Grain"
(http://www.design21sdn.com/challenges/15 )
competition. Entries close June 2nd, 2009
Feb 9, 2009. 12:47 PMrveinot says:
If you were to drill a hole down through the center of the cross over of the legs , add a bolt (1/4" ) and use a plastic knob you should increase rigidity to the legs when you tighten the knob. You could even drill all the way though the top (for the bolt) to add even more rigidity.
Mar 25, 2008. 2:00 PMstatic says:
Nice instructable. Thanks for making the drawings available. Any chance you will be making the drawings available for the round table available or does the slight bend in the parts make it unfeasible for the home shop?
Mar 24, 2008. 9:54 AMgosub says:
Not easy to cut by hand but excellent design for building a cheap table. The cuts needs to be painted or something.
Mar 25, 2008. 1:42 PMstatic says:
Hand tools power or otherwise, or a combination there of, should be sufficient to build this project. IMO the contrast of the unfinished edges on the black table look great, but no so much on the white table. Anyway one can finish to their own taste, to state the obvious. :)
Mar 21, 2008. 6:03 PMteaching with joy says:
I'm enamored with the design, but lack the skills, tools, work area, etc. to create them. :( Questions! I have questions! Could I find the specialized cutting tools you mention in Raleigh, NC? Is it expensive to hire someone cut these for you?
Mar 21, 2008. 10:03 PMGonazar says:
Try here to get it prefabed - http://www.ponoko.com
Mar 21, 2008. 10:07 PMGonazar says:
My bad, they only make things up to 31x15 inches
Mar 21, 2008. 12:24 PMkosmicslop says:
I love these tables. However, before reading and just looking at the pictures, I thought they would be perfect for someone like myself who moves around a lot. It would be a lot easier to pack tables that could break down like that. Any suggested mods to make that a more real possibility?
Mar 20, 2008. 11:13 PMGTecb says:
Very good idea! Thank you and good luck!
Mar 20, 2008. 4:20 PMDesBourgeois says:
OOO you should post this design on Ponoko.com's gallery! Neato!!!
Mar 20, 2008. 4:20 PMtoekneebullard says:
These look awesome. I would totally make this is I knew someone who had a laser or water jet cutter. This would be great for a kids room, cheap materials, but sturdy, so they could do whatever they wanted to it, and you wouldn't have to worry.
Mar 19, 2008. 11:23 PMMr. Rig It says:
I like your thinking, these are my kind of projects. i'll be looking for more from you. Good job. you get a +.
Mar 18, 2008. 9:52 PMGorillazMiko says:
That's so awesome, and great job! Did you take the pictures?
Mar 18, 2008. 9:08 PMkharmsengine says:
I'd suggest using birch iron-on edgebanding.
Mar 18, 2008. 8:14 PMausable says:
Great design!
Mar 18, 2008. 4:04 PMdarkmuskrat says:
Cool, if u can turn a 4x8 into "2" tables, I figure that would help a lot of people.
Mar 18, 2008. 8:21 AMjdege says:
Ply isn't generally dimensionally accurate in its thickness. A sheet with a nominal thickness of 24mm might be 24mm thick, or it might a bit thicker or a bit thinner. (Usually, it's thinner). The stiffness of this table depends heavily on the fit of the joints - particularly of the half-joint in the legs - and this fit is dependent on the thickness of of the cuts matching the thickness of the material. So I'd suggest that you either adjust the cutting plan to match the measured thickness of the material you're using, or carefully select the material to match the thickness of the cuts you're making. Don't assume that a 24mm piece of ply will fit tightly in a 24.5mm slot, just because the label on the ply says 24mm.
Mar 18, 2008. 7:59 AMgmjhowe says:
wow, this table is very cool. great for any kind of workshop, cos it can easily be put to one side. infact i would be tempted to add like a clip to hold the legs in place after cutting. Instructable is done well also!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:barnabygunning
