3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
8x4=2 (2 Tables from 1 sheet of plywood)
Step 2Cut the ply
Cut the ply
If you are brave enough to cut this by hand you will need to mark up the upper face of a 1220mmx2440mm sheet using the downloaded drawing.
The design is fairly tolerant of inaccuracy in the jigsaw cutting but you will need to cut the slotted holes in the lid to provide a tolerant holes for the tabs on the leg frames.
If you are using 12mm ply you will need to glue and clamp the pairs of table tops and legs to eachother. PVA glue will do the trick. You should clamp the leg frames on their tabs and about 10cm from the end of each leg. The table top needs clamping over the slotted holes.
1 comment
Dec 7, 2010. 5:42 PMtechfix1 says:
This is one nice looking table and practical!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:barnabygunning
