8x8 LED MATRIX DISPLAY | ARDUINO | BLUETOOTH CONTROL
3,477
60
36
Posted
Introduction: 8x8 LED MATRIX DISPLAY | ARDUINO | BLUETOOTH CONTROL
In this tutorial i show how to build a 8 x 8 LED matrix using an Arduino .
DO COMMENT WHAT YOU THINK ABOUT THIS INSTRUCTABLE,SO THAT I CAN IMPROVE IN MY FURTHER INSTRUCTABLES
have a look at the video tutorial for a better understanding of the entire tutorial.
PARTS NEEDED:
☻LEDS( 64 PCs)
JUMPER WIRES
☻CARDBOARD PIECE(16 CM BY 16CM)
ARDUINO UNO
LAPTOP OR PC (FOR UPLOADING CODE TO ARDUINO
POWER SUPPLY ( I USED A POWER BANK TO SAVE BATTERIES)
Step 1: ASSEMBLE THE CIRCUIT USING CARDBOARD SHELL
PUT IN ALL THE 64 LEDs IN THE CARDBOARD PC AS SHOWN
Step 2: SOLDER THE LEDS AS PER THE CIRCUIT DIAGRAM
FIRST SOLDER THE POSITIVE TERMINALS OF THE LEDS ROW WISE
NEXTBENDTHE NEGATIVE TERMINALS A LITTLE BIT AND SOLDER THEM COLUMN WISE (AS SHOWN) ACCORDINGLY.
EDIT: JUST ADDED FEW EXTRA IMAGES TO UNDERSTAND THE SOLDERING PART A LITTLE BETTER
Step 3: SOLDER JUMPER WIRES AND POP THE CIRCUIT OUT
SOLDER 8 JUMPER WIRES IN THE ROWS AND 8 JUMPER WIRES IN THE COLUMN .
FINALLY POP THE CIRCUIT OUT OF THE CARDBOARD SHELL
Step 4: ARDUINO
CONNECT THE AURDUINO WITH THE LED MATRIX
CONNECT EACH OF THE COLUMN TO PIN 2,3,4,5,6,7,8,9 RESPECTIVELY
ALSO,CONNECT EACH OF THE ROW TO PIN 10,11,12,13,14,15,16,17 RESPECTIVELY.
FINALLY UPLOAD THE FINAL CODE TO THE AURDUINO THROUGH THE CONNECTING WIRE
To download the final code go to the below link :
https://drive.google.com/open?id=1rQIDh56OnBVF2rqVtHd0UK7_qQ4WNjcZ
Step 5: CONNECT BLUETOOTH
CONNECT THE BLUETOOTH DEVICE HC-05 TO THE AURDUINO:
connect rx of bluetooth to tx of arduino
connect tx of bluetooth to rx of arduino
vcc to +5v
gnd to gnd
Step 6: Download Android Application
download arduino bluetooth controller from playstore
Step 7: Let's Play With the App
click on connect and select your bluetooth device .
congratulations!! you have a working led matrix display controlled via bluetooth
  • Science of Cooking
    Science of Cooking
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
Hi, I can't open the sketch. I keep getting errors...Could not create the sketch and Failed to open sketch:"C:\Users\Office\Downloads\led_matrix_8x8 final code\led_matrix_8x8 final code.ino" Do you have another link to the sketch. I've spent 2 days making this and I'm really want to finish. Any help would be greatly appreciated.
17 Comments
Can we not use 8x8 matrix LEDs instead of assembling 64 leads in the matrix form? It makes things easy. I hope your code should still work.
YOU MAY BUT THE CODE WON'T WORK I GUESS...ALSO THIS IS MORE FUN TO ASSEMBLE :)
Thank you for the prompt reply. I also believe that the code won't work.
I did everything with 8*8 matrix display.
Lights are blinking when we give commands in mobile.
What can I do now
Very nice. I voted for all 3 categories. What is the spacing of the LEDs?
Will the HC-05 work with the iPhone?
Ya i guess app is available in the app store
Nicely done. If you could put 3 or 4 of them together you could make a nice scrolling display.
yeah nice idea...would try to do that soon :)
